Gurgling noise coming from heater box?
Old Nov 25, 2013 | 06:04 PM
10 Second Club
Default Gurgling noise coming from heater box?
Been hearing it a lot lately, it is something new. Any idea what this mystery noise is?
Old Nov 25, 2013 | 06:08 PM
Byrdman11's Avatar
Low on coolant for sure.
Old Nov 25, 2013 | 06:51 PM
01silvy's Avatar
mine does the same thing occasionally if I am sitting in it and it is ideling while fully warmed up. I probly just need to remove the reservoir cap and try to get more air out of the system. I have no negative cooling issues
Old Nov 25, 2013 | 07:06 PM
10 Second Club
Low coolant light isn't on, truck runs cool. I'll check the level again tomorrow. Funny thing is, this started once the weather got colder. I bought the truck in July, the noise started about a week ago.
Old Nov 25, 2013 | 07:56 PM
Byrdman11's Avatar
It low coolant. Put the cap and check it. Let it warm up and check it. You will see my friend.
black00chev's Avatar
Slowest turbo build ever!
Mine did that when I would be using defrost on cold mornings. Ever since I had my coolant flushed it stopped.
Old Nov 25, 2013 | 08:04 PM
Byrdman11's Avatar
You are hearing air bubble in the coolant rushing in the heater core. If you rev the engine in neutral you will hear it too.
Old Nov 25, 2013 | 10:35 PM
Vortec350ss's Avatar
I swore up and down I had the same issue... Turned out it was my gauges making the noise. Very weird. Mine was faint though.
Old Nov 25, 2013 | 10:50 PM
"CARTER"'s Avatar
Registered User
Same here. I just here it at idle and when I rev it it kinda goes away. My defog and heaters rent wrking.. Wonder what it is. As soon as the weather gets better I'll dig under the hood
Old Nov 25, 2013 | 11:29 PM
Ferocity02's Avatar
Mine did this too, it was just because of low coolant. It would happen even when the low coolant light wasnt on.
