Flex-a-lite fans
Which flex-a-lite fans fit 03 trucks. Is it the 310's?
Fan Specifications
Mounting Surface Required: 22 x 11-1/4 x 4-1/8 inches
Fan Diameter: 10 inches each
Fan RPM @ 13.5VDC: 2500
Number of Blades: 10
Air Flow @ 0-inch static pressure: 1800 CFM
Amp Draw: 15 amps
Mounting System: Thru Core
Fan Specifications
Amp Draw: 15 amps
I put the 292 in mine, but it took a bit of cutting to make it fit, and I had to fab up some bottom brackets. Not too hard to do. Something I would recommend is replacing their variable speed controller with an upgraded unit. They might be OK now, but when I got mine they were getting some cold solder joints in their production, causing a lot of grief. If you want, I can PM you the name of a good one.
weel its kinda off subjet but why spend money on flexalite when you can make your own setup with about 125 bucks all you need is 2002 chevy impala fans and your proper wireing and relays and about an hour of your time, only thing difficult is having to make your own wirering kit but i guarantee you guys that they flow twice as much as any other aftermarket e-fans I have 2 friends of mine that swamped out thier flexalites for the impalas and have gotten better cooling performance IMO its well worth the 125 bucks it cost me to do
Originally Posted by SnakeOiler
OK, I have to know. What did you cut and why did you need bottom brackets?
I should point out that you will peobably not have these problems because, as V8 mentioned, they've changed the kit. Also my truck seems to be some kind of an oddball, where bolt-on parts usually don't. Makes things interesting.
Anyway good luck, you'll love the fans once you get them in.
Wrecker 426
Sep 30, 2015 09:39 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
