fan harness
Old Dec 10, 2006 | 04:12 PM
stone150's Avatar
Default fan harness
how do you hook op one of white1's harness? and what realys do i need
Old Dec 10, 2006 | 07:12 PM
COLDZ71's Avatar
The relays should all be hooked up on the harness. That is the way mine was anyway. I might be able to get the directions that came with mine if you would like.
Old Dec 11, 2006 | 12:02 AM
stone150's Avatar
that woulb be great, i didn't get realys bec when i got it form him he was out of the states
Old Dec 11, 2006 | 05:32 AM
COLDZ71's Avatar
I will try and get it to you by this evening.
Old Dec 11, 2006 | 05:35 PM
COLDZ71's Avatar
Damn dude sorry. Went out and looked and I must have thrown it in the woodstove thinking I really wouldnt need it again. Hopefully someone who knows how to do it real good could help you out. I had to follow the directions close since I wasnt sure what I was doing.
Old Dec 12, 2006 | 09:06 AM
stone150's Avatar
ok cool, anyone?
Old Dec 12, 2006 | 10:10 AM
Nick™'s Avatar
it's the same directions as for the Nelson Harness. the PCM Pin goes to slot #42 of the Blue connector on the PCM. The loose wire with no end gets tapped into the a/c clutch turn on wire, that wire is located in the harness right behind the alternator/ the red box. The wire color is green, but I forget if it's the one with the stripe or not, if you crawl under the truck and look at the a/c compressor there is two wires plugging in behind the compressor pulley, that's the same wire, note it and find it up near the alternator and use a T-Tap to connect. The relays you'll need are 30/40 Bosch style relays, it's a typical automotive relay and looks like these:
http://cgi.ebay.com/ebaymotors/SPDT-...62592653QQrdZ1
I won't endorse any particular brand. The harness is built so that you can either mount it to the fuse center cover or it should fit under the cover
Old Dec 12, 2006 | 10:12 AM
stone150's Avatar
ok, i also if i remeber had a red wire too. and what do i need to do to the pcm to get these to work
CD82
Oct 23, 2015 07:32 AM
Wrecker 426
Sep 30, 2015 09:39 PM
Silver8ado
Sep 30, 2015 11:42 AM
StrokeTheLS
Sep 29, 2015 08:33 PM
old motorhead
Sep 29, 2015 08:22 PM
