Eradispeed
Old Sep 16, 2015 | 02:49 PM
.J.'s Avatar
.J.
Default Eradispeed
IS IT POSSIBLE TO MAKE A 15inch ERADISPEED-PLUS 1 FRONT ROTOR (2005-2015 GM TRUCK)FIT A 2001 TRUCK ?
IT SEEMS THEY ONLY SELL 14inch for 1999-2005.
Old Sep 17, 2015 | 05:28 AM
mikeyjm1's Avatar
I would think it fits. my NNBS fronts all bolted up like stock.
Old Sep 18, 2015 | 03:42 AM
.J.'s Avatar
.J.
Thank you.
Old Sep 19, 2015 | 02:49 PM
1Bear's Avatar
It should work just fine as long as you install the matching ’05 up calipers as well, beings that’s what the caliper brackets were designed for.
Old Sep 20, 2015 | 03:38 AM
mikeyjm1's Avatar
What he said.
Since my truck had the older 12.x" brakes, I upgraded with the newer 13" rotors, pads and calipers. The caliper mounting holes and lug patern stayed the same so as long as you upgrade all three, theres no reason it shouldnt work.
Old Sep 22, 2015 | 11:03 AM
.J.'s Avatar
.J.
Several years ago I installed SSBC (Quick change) calipers on my '05 Escalade and used some off them to change with the ones on the C3.
I can't remember if the brackets match , if I hear what you say is right then they don't fit ?
Old Sep 24, 2015 | 02:51 PM
zeake's Avatar
If you have not done hydro boost conversion it is a much much better mod than eradispeed. I learned the hard way.
Old Sep 25, 2015 | 02:01 PM
.J.'s Avatar
.J.
Just ordered 2 15'' front kits yesterday,if it does'nt work on the c3 ill bolt them to my '10 denali.
Can you enlighten me zeake?
Old Sep 25, 2015 | 05:38 PM
zeake's Avatar
I had a 99 rcsb with bear 15" brakes and stainless braided lines. My 2004 2500hd ccsb with stock brakes would stop better than the much lighter 99 rcsb with 14" rotors front and rear. Hydroboost was that much better. Hydroboost and big brakes would be really good. I don't much like bear brakes though. two expensive for replacement rotors and you shouldn't turn them. With hindsight I'd go with SSBC brakes.
https://www.performancetrucks.net/fo...nstall-417445/
https://www.performancetrucks.net/fo...on-how-515579/
Old Oct 3, 2015 | 03:11 PM
.J.'s Avatar
.J.
Came to conclusion today brackets are indeed diff. Trying on Monday if you can swap the bracket from 05> to 01. Anyone that has experience?
