Engine build question
Old Jan 28, 2012 | 09:50 AM
40series's Avatar
Default Engine build question
How long or how many miles can i one expect to get from a engine build if he was only re-building the top of the motor - heads, cam intake etc.
How many long can i expect to get from a complete rebuild crank bearings , line hone etc.
Old Jan 28, 2012 | 10:17 AM
JFOLM's Avatar
The only benefit I would see from a top end build would be replacing the lifters with fresh ones. As long as it was a functional high mile engine.
A complete rebuild, guess it depends on if it is mild or wild and who tunes it. I don't see why a stock rebuild wouldn't be good for 200k miles.
Old Jan 28, 2012 | 10:18 AM
sandbum's Avatar
kinda a non answerable questions, depends on lots of things,
maintenance, driving habits, ive seen 5.3s above 250k come into the dealership still sounding like day one, and we had a 08 silverado with 40k on it just grenaded.
Old Jan 28, 2012 | 10:24 AM
sandbum's Avatar
I would deff replace valve springs, or atleast check there yield limits.
Old Jan 28, 2012 | 06:35 PM
40series's Avatar
Default thinking of building a stroker
Originally Posted by sandbum
i would deff replace valve springs, or atleast check there yield limits.
i was looking into building the bottom into a stroker. With the way i drive which is all out i just want the best build i can do . Mind you i never built the bottom, but the top looks very do- able. Granted ive put sythetic in my 04 since day one so i feel the bottom should be fine
Old Jan 30, 2012 | 07:32 PM
40series's Avatar
Default @ 120000 is it wort rebuilding
is running motor 2 120000 worth re building . Do i need to rebuild it from the bottom up or can i just add parts heads cam an such
Old Jan 30, 2012 | 07:38 PM
1FastBrick's Avatar
Custm2500's Rude Friend
For the best possible results, do a full rebuild. If your bottom end is clean and has good compression, a top end would proably be just fine.
Old Jan 30, 2012 | 08:16 PM
TXSZ66AVLANCHE's Avatar
Just a top end parts swap is not a rebuild of any sort...
5.3lSilverado
25
Aug 29, 2016 12:48 AM
USMCvet0311
Aug 14, 2015 10:28 PM
Austino
Jul 30, 2015 03:28 PM
bbowerman
Jul 26, 2015 10:57 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
