E-fan/ fan clutch Help!!
What do you do if the belt is not holding th clutch in place? I can spin by hand with a crescent wrech. 832-514-8190 call for a faster response working on it right now.
hit the wrench with a big hammer to jar it loose.
take the belt off and loop it over the water pump pulley, double it up and loop it over the crank..
its goin to bind on itself and shouldnt slip. but good luck with only two hands.
Nonnieslman- I owe you a twelve pack, F-ing yeah man **** worked good, I shouldve remembered that. We use to use ratchet straps in the same manner in the Army, if you dont use it you lose it.
Wrecker 426
Sep 30, 2015 09:39 PM
Shotguntommy
Sep 15, 2015 05:24 AM
