Drivers side window regulators
Old Jul 3, 2011 | 07:47 PM
Half-bred's Avatar
Default Drivers side window regulators
This probvably not the right section but who has had problems with the drivers side window reg. I've replaced mine twice already and it keeps taking a #$@#, Is it a common problem please help thanks
Old Jul 3, 2011 | 08:49 PM
TIM Z's Avatar
11 sec. Truck Mod
Where are you buying them from, aftermarket autozone stuff is junk.
Try to get factory replacements.
If you already did you may have a short that is eating them up??
Old Jul 3, 2011 | 09:48 PM
mitchellmade's Avatar
MASS seller approved
A trick I learned that makes everything last longer is clear silicone lube spray in the tracks put window up and down a few times then wipe off excess helps even if your windows barely go up and down or work like new
Old Jul 3, 2011 | 10:10 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Unless something in the door is bent/misaligned, it's most likely a problem with using low quality parts. I always recommend dealer parts for the window motors, and window regulators.
Old Jul 3, 2011 | 10:26 PM
Half-bred's Avatar
Thanks for the help. off to the dealer
Old Jul 3, 2011 | 11:50 PM
bow tie guy's Avatar
Try kay auto AC delco wholesale
Rock auto may have the AC delco as well
should be like 112.00 for the whole Enchilada
Old Jul 4, 2011 | 09:07 PM
budhayes3's Avatar
PT's Slowest Truck
+1 on all of the above...the aftermarket regulators are junk and don't last very long, and I've found, with most manufacturers' power windows, that some silicone spray in the window runs will allow for a nice low friction surface which will take some strain off of the window regulator/motor
The_W
Oct 28, 2015 09:00 PM
85SS/85GN
Aug 7, 2015 04:30 PM
vipergtrdj
Aug 6, 2015 10:19 PM
zblee
Aug 3, 2015 03:45 AM
