Drivers side window regulators
This probvably not the right section but who has had problems with the drivers side window reg. I've replaced mine twice already and it keeps taking a #$@#, Is it a common problem please help thanks
A trick I learned that makes everything last longer is clear silicone lube spray in the tracks put window up and down a few times then wipe off excess helps even if your windows barely go up and down or work like new
Unless something in the door is bent/misaligned, it's most likely a problem with using low quality parts. I always recommend dealer parts for the window motors, and window regulators.
zblee
Aug 3, 2015 03:45 AM
