Drive train problems
Old Dec 17, 2008 | 01:02 PM
ski7541's Avatar
Default Drive train problems
Hello from Afghanistan,(DEployed) I have 04 GMC,1/2 ton,2 wd,4-door,5.3. The problem I am having is I have a viberation between 85 to 92 mph and then it stops doing it the faster I go or I slow down. It has done this afterI installed the programmer to go faster...I took it to two different dealers with A IDK look.... I am fixing this problem when I return home, so doing my homework now...any suggestions ? Thanxs SKI
Old Dec 17, 2008 | 01:10 PM
454navyss's Avatar
dont drive above 85mph, that is faster than the speed limit everywhere in the US
Old Dec 17, 2008 | 01:31 PM
ski7541's Avatar
Funny guy....Still it should not do that!!!! And I like to drive fast...
Old Dec 17, 2008 | 03:24 PM
454navyss's Avatar
make sure everything is balanced correctly, driveshaft, tires, etc. also check u-joints. does it vibrate in the front or back?
Old Dec 17, 2008 | 06:23 PM
Truckshop's Avatar
crew cab with a 1 piece driveshaft. it is too long. the only way to fix it is to convert to a 2-piece. they are pretty famous for flying from under the truck at speeds over 100.
Old Dec 17, 2008 | 10:43 PM
ski7541's Avatar
Ouch, flying out at over 100....
Old Dec 17, 2008 | 10:46 PM
ski7541's Avatar
Have you converted one? or has anyone done this...if so which truck did the 2 piece D/S come from..
Old Dec 17, 2008 | 10:53 PM
ski7541's Avatar
The vibe, is in the rear...
Old Dec 20, 2008 | 01:47 PM
Truckshop's Avatar
if you are stock height then you can get one from a 2wd extended cab truck. all you will need to do is make a support for the center bearing.
black03rcsb
Sep 1, 2015 10:17 AM
MattOKC
Aug 18, 2015 11:30 AM
05GMC4.8
Aug 7, 2015 09:55 PM
walledition
Jul 29, 2015 08:54 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
