Daytime running lights Problem
Old Jul 12, 2004 | 03:01 PM
900Z1's Avatar
Default Daytime running lights Problem
I have had my truck for about 6 months now, I have replaced the passenger
Daytime Running Light 3 times. I have noticed that every GM truck I have seen
with a DRL bulb out was always on the passenger side.
The last bulb I had to replace was an LED bulb, as I thought it would last longer
but It did not.
Anyone know of a GM bulletin for this problem ?
All help appreciated
Old Jul 12, 2004 | 03:14 PM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
Buy some electrical grease from Pep Boys or whatever your local automotive store is. I spent $2 on some and haven't had a burned out bulb since
Old Jul 12, 2004 | 04:10 PM
Dielectric grease
Buy it at any hardware store - Ace sells the little tubes.....FYI
Old Jul 12, 2004 | 05:07 PM
900Z1's Avatar
So I just put grease into bulb socket and that heals it?
I won't ask how it works I will just Do It.
Thank you very much for info.
Old Jul 12, 2004 | 06:50 PM
goshawk23's Avatar
Truck addict
yup....i see so many damn trucks with the one eye closed syndrome. always the passenger side as you described. use that grease for everything under the hood that is electrical.
Old Jul 13, 2004 | 08:09 PM
900Z1's Avatar
Bought some Dielectric Silicone Grease GM part #12345579
10 bucks for a one ounce tube. Damm!
Old Jul 16, 2004 | 08:15 PM
chevymec's Avatar
GM has made a new bulb that is a 14 volt bulb. It is a 4114k bulb. GM part number is 15199562.
Old Jul 17, 2004 | 09:57 AM
2ksleeper's Avatar
Make sure you replace the bulb with the exact part # listed I believe it is 3157KX. I believe the ones you buy at std parts stores dont have the KX at the end of the part# & wasnt designed to be runned all the time. When I replaced mine I couldn't find one at the parts store so I had to go to the dealer. My truck is about 5yrs old & I have only had to replace both bulbs once.
ferrellrooster
Mar 6, 2025 03:22 PM
stealthperf
34
Feb 14, 2016 11:35 AM
silver-mod-o
Jul 27, 2015 05:24 PM
Ketis
Jul 23, 2015 12:37 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
