Cold Natured
Old Jun 11, 2007 | 12:01 AM
regency's Avatar
Default Cold Natured
exactlly what makes a motor cold natured, either a carb. motor or a fuel injected motor
Old Jun 11, 2007 | 11:05 AM
shandy294's Avatar
I think it points to a problem and is not something unavoidable or inevitable. A newer engine might have a IAC tha's dirty,for instance,or something else faulty in the system that is just for cold start/run situations. Carbed engines sooner or later will develop choke (or choke pull-off) problems.
I had a 86 305 that had a bad vac. break (pull-off) diaphragm that had a pin hole. It looked like it was working(moving the choke butterfly)but would run really rich until the choke opened-up.
I guess this pertains to stock engines that have well-designed cold start/run systems that are working right. HP and other special applications may not have much,if any,cold-run stuff.
Old Jun 12, 2007 | 01:56 PM
regency's Avatar
cool, thanks man
anymore opinions fellas
im trying to get a little more educated here!!!!!!!!
Skip Fix
22
Jul 9, 2016 07:08 PM
turbo6c3
Oct 5, 2015 06:11 PM
OHsixLS3
Sep 25, 2015 04:38 PM
Closer_2001
Sep 24, 2015 09:15 PM
fortune46x
Sep 16, 2015 08:18 AM
