Clutch fan with no shroud?
Old Nov 4, 2007 | 05:14 PM
BlackLM7's Avatar
Default Clutch fan with no shroud?
Is it OK to run a clutch fan with no shroud? I plan on getting some 292 Flex a Lites soon and I decided to remove my fan shroud today to get an early head start on the e-fan install. I drove around monitoring my engine coolant temp with AutoTap software and the temp never rose above 196* while moving. I idled in a parking lot for about 10 mins. and the temp got to 218* and stopped. This is pretty normal compared to before when I had the fan shroud on. So...is it OK to have no fan shroud? At least it's cleaner under the hood.
Old Nov 4, 2007 | 06:21 PM
sbw9056's Avatar
As long as you watch your temperatures, you will be fine. If it were summer time and you were using AC or towing, you might need the shroud. The fan shroud just makes the fan move air more efficiently.
Old Nov 5, 2007 | 05:09 PM
howard quick's Avatar
Watch your fingers!
Old Nov 6, 2007 | 07:45 AM
hirdlej's Avatar
Watch your dingy!
Old Nov 6, 2007 | 11:44 AM
aaronmc's Avatar
I run it without a shroud for the same reason and havent had a problem.
Old Nov 6, 2007 | 11:56 AM
thunder550's Avatar
High on diesel fumes
Originally Posted by hirdlej
Watch your dingy!
Hahahaha
Wolftrk99
Dec 3, 2015 08:12 PM
CD82
Oct 23, 2015 07:32 AM
Wrecker 426
Sep 30, 2015 09:39 PM
old motorhead
Sep 29, 2015 08:22 PM
97_ek
Sep 23, 2015 09:16 PM
