casting numbers?
Old Nov 27, 2011 | 01:10 AM
  #21
1FastBrick's Avatar
Custm2500's Rude Friend
Originally Posted by 121
it is a back up engine and not real sure about and the knock sensors etc.. will this work or not?? got a good deal on this from a dealer and just checking and all things before i do anything. so please let me know!! thank you
If you want to use it in a 2010 vehical you will need extension harness for the knock sensors. Also the Cam and Crank signal will have to be converted. I beleve the cam sensor is on the front in a 2010 were as in say an 05-06 it would be in the rear. Also the crank will mostlikely be 24X crank wheel signal and you will have to run a 58X crank wheel to work for the 2010. or use a stepper box but I cant remeber if it steps up or down...
You would have to read up on all the stuff to convert it to work in a 2010. It can be done but you might be better off getting the correct style engine to keep it simple.
Old Nov 27, 2011 | 01:16 AM
  #22
121's Avatar
121
yea i will have to check into all of this be better off if it was the same.
Old Dec 19, 2013 | 07:04 PM
  #23
rollwithit's Avatar
Thats a 5.3L. There is a production date cast into the top area were the water pump coneects to the block. Should look like A105 This is an example The leter indicates the month A= january and so on. the rest would be the day of the month. in this case 10 = 10th of january and the last should be the year 5 = 2005...
mine says m120 any idea?
Old Dec 19, 2013 | 07:42 PM
  #24
1FastBrick's Avatar
I don't have an exact Julien date break down but maybe this was December.
December 12, 2000
nabozny21
Oct 17, 2015 07:47 PM
KINGCYCLES
Oct 2, 2015 10:21 AM
Wolftrk99
Oct 2, 2015 08:17 AM
KleanKustoms
Sep 30, 2015 05:07 PM
Slammed silverado
Sep 28, 2015 06:14 PM
