casting numbers?
Old Nov 26, 2011 | 06:21 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Originally Posted by 121
ok i found more info on this block.. they said 2006 suburban so late 05 i bet. they pulled the engine because the oil light was coming on and off so they said oil pump could be bad or spun a rod or main bearing. i took all the main caps off and they look good i will check rods when i get more time. the main thing i wanted to know is if it was a 5.3 and you have ben alot of help. thank you!
Sounds good.
Could have been a couple things, the Barbel in the back of the block, the o-ring at the pump pick up, or a cam bearing could have spun and become miss aligned blocking the flow of oil. You know once you get it apart.
Old Nov 26, 2011 | 06:24 PM
121's Avatar
121
Sounds good.
ok man thanks again for all your help if i have more questions ill shoot you a msg.
Old Nov 26, 2011 | 06:25 PM
1FastBrick's Avatar
Usually when a rod bearing goes there is evidence on the main bearings.
These types of oil pumps don't generally go bad, but it has happened. Usually there is something else like poor maintence that causes it though...
Old Nov 26, 2011 | 06:29 PM
121's Avatar
121
Im going to build it as a back up motor so im going to put cam rod and main bearings,new cam and forged pistons, new oil pump and anything else i see wrong.
Old Nov 26, 2011 | 06:34 PM
1FastBrick's Avatar
Good deal. If you dont find a cause upon tear down. Make sure you Check all the oil passages before you clean and replace everything. Wouldn't want to find a blockage the hard way...
Old Nov 26, 2011 | 06:40 PM
121's Avatar
121
ok i will inspect everything good. i dont want to find out the hard way!
Old Nov 26, 2011 | 07:22 PM
121's Avatar
121
My truck is 2010 everything should be fine for bolting up i believe.. sensors and tranny etc.
Old Nov 26, 2011 | 08:33 PM
slow2008's Avatar
formerly slow03 (11-04-2011)
Is it me or does the 3rd piston from the left look a little chewed up?
Old Nov 26, 2011 | 09:09 PM
1994Vmax's Avatar
So you are swapping a generation 3 5.3 into a Gen 4 equipped 2010 truck? Your knock sensors and crank trigger are different between those two unless you already know this and are dealing with it accordingly.... Or should I say will as this is just a backup engine if I am reading this correctly.
Old Nov 27, 2011 | 12:42 AM
121's Avatar
121
it is a back up engine and not real sure about and the knock sensors etc.. will this work or not?? got a good deal on this from a dealer and just checking and all things before i do anything. so please let me know!! thank you
