Camaro 6.2 in silverado
I wonder 2011 camaro ss 6.2 376 enine able swap put in 2006 Silverado? Do I have to get different wiring harness make it work with all newer model sensors things?
I think it will but you would probably need to get one of this Lingenfelter TRG-002 58x-24x Crank Sensor Trigger Conversion Module - Lingenfelter Performance
I THINK , NOT 100% SURE
LMK, We are a Lingenfelter Distributor.
there is a ton of info already on this site about what is needed to run in a gen3 motor.
thats interesting, im doing some research and I wonder how it work if buy a harness for ls3 go to connect my current pcm or what. Stock ls3 with turbo how much hp it will making?
I woulndnt buy another harness when nothing is wrong with yours.
Buy the 58x to 24x conversion module, cut and solder the knock sensor wires, drill the side of the block close to the current knock sensor hole *leave the oem holes alone so you can go back to a 07+ gmt900 truck if you want* slap in a z06 cam, 7.425" pushrods, an get the idler relocator kit to run your truck acc on the LS3.
gcsd3742
Jul 6, 2015 05:22 PM
