Camaro 6.2 in silverado
Old Dec 4, 2011 | 10:38 PM
Go5.3tt06's Avatar
Default Camaro 6.2 in silverado
I wonder 2011 camaro ss 6.2 376 enine able swap put in 2006 Silverado? Do I have to get different wiring harness make it work with all newer model sensors things?
Old Dec 4, 2011 | 10:56 PM
1slowz71's Avatar
I think it will but you would probably need to get one of this Lingenfelter TRG-002 58x-24x Crank Sensor Trigger Conversion Module - Lingenfelter Performance
I THINK , NOT 100% SURE
Old Dec 5, 2011 | 09:27 AM
BlownChevy's Avatar
blownerator
25 Year Member
correct, the Knock Sensors, and cam sensor are also in different locations. There are harnesses available for these.
LMK, We are a Lingenfelter Distributor.
Old Dec 5, 2011 | 09:42 AM
iamkeniff's Avatar
you dont need the cam sensor harness, that 58x to 24x conversion box has a long enough cam sensor harness to run it to the front of the motor. the knock sensor harness can be cut and extended for little money or spend the 55.00 on a extension harness, your choice.
there is a ton of info already on this site about what is needed to run in a gen3 motor.
Old Dec 5, 2011 | 06:25 PM
Go5.3tt06's Avatar
thats interesting, im doing some research and I wonder how it work if buy a harness for ls3 go to connect my current pcm or what. Stock ls3 with turbo how much hp it will making?
Old Dec 6, 2011 | 08:57 PM
iamkeniff's Avatar
I woulndnt buy another harness when nothing is wrong with yours.
Buy the 58x to 24x conversion module, cut and solder the knock sensor wires, drill the side of the block close to the current knock sensor hole *leave the oem holes alone so you can go back to a 07+ gmt900 truck if you want* slap in a z06 cam, 7.425" pushrods, an get the idler relocator kit to run your truck acc on the LS3.
Old Dec 6, 2011 | 09:10 PM
Mangled03gmc's Avatar
Baltimore Whore
Before you do any of the above mentioned, you better have your self a built l80e trans ready to go in, a good center section and gears.. Just saying
Old Dec 7, 2011 | 05:58 AM
iamkeniff's Avatar
^^^^ aint that the truth!! i can see a burn up clutch or two in the near future of that 60e
Vash3233
Sep 22, 2019 01:18 PM
zo6freak
14
Oct 18, 2015 06:43 PM
TXsilverado
Sep 26, 2015 12:48 AM
rudvirus
Aug 5, 2015 08:05 PM
gcsd3742
Jul 6, 2015 05:22 PM
