cam install help starter removal
Old Jun 29, 2005 | 11:30 PM
black4x4's Avatar
Default cam install help valve seals
I have the 2 bolts that hold the starter in out and the starter is loose now do i need to disconect any wires or should it be able to be pulled out as is?
Old Jun 30, 2005 | 09:22 AM
white1's Avatar
Just fyi its a total pita and it's a bitch to re install. Try pulling the larger round plug in the bellhousing instead.
Old Jun 30, 2005 | 09:25 AM
BigKID's Avatar
Just be sure to unhook your battery first.
Old Jun 30, 2005 | 10:43 AM
hellbents10's Avatar
LS1Tech Sponsor
Its rather easy to get out if you remove the oil dipstick. Then you should be able to slide it twords the front of the truck and drop it down. I usually zip tie it up out of the way and get the converter bolts when I am pulling a trans. BTW I do not disconnect the wires either.
Old Jun 30, 2005 | 01:44 PM
black4x4's Avatar
I orderd new valve seals but i think they are the wrong ones i need the ones like i have on my truck now i been told to clear the dual springs i have. Now could i remove the ones i have currently install my new seats and then reinstall the seals or should i try to find a new set.
Old Jun 30, 2005 | 04:51 PM
FormerVendor
You need the 2001-below valve seals part numbers 12457652 & 12533586. The 2002 and later are a one piece valve seal/spring seat combo and will not work with the dual springs. The duals have their own spring seat. Just get these seals from GM and get those springs and cam installed. Joe.
Old Jul 1, 2005 | 08:32 PM
black4x4's Avatar
how many bolts hold the oil pan on it doesn't seem to want to drop down.
Old Jul 5, 2005 | 03:06 AM
I'm in the middle of my cam swap and I discovered you don't have to drop the starter to lock the motor. You just have to take off the plastic cover below the starter, that will expose a big chunk if the flywheel to work with. I then stuck a piece of 5/16 rod left over from my lifter tool between the teeth and the skidplate.
Old Jul 5, 2005 | 11:50 AM
white1's Avatar
I didn't have to drop the pan. But there are two bolts on the bottom of the timing cover that have to be removed. Hope you have a set of gear wrenches.
Choda
Jan 22, 2026 02:03 PM
all_individual
Oct 10, 2015 10:09 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
bsn1989
Jul 16, 2015 08:20 AM
all_individual
Jul 13, 2015 11:01 AM
