brake and abs light on
Old Feb 19, 2010 | 08:58 PM
slowswb's Avatar
Default brake and abs light on
this what going on i start the truck up and the abs and brake light comes on and says service brakes. i shut off the truck and start it back up it goes away. this ding crap is starting to get annoying if you know what mean but info how to fix this would be great.
Old Feb 19, 2010 | 09:53 PM
budhayes3's Avatar
PT's Slowest Truck
Could be a number of things, really need to know what code(s) it has to begin to diagnose it...could be anything from a bad wheel speed sensor to a bad ABS module
Old Feb 19, 2010 | 09:58 PM
slowswb's Avatar
never knew that you get codes when the abs light is on. nope haven't got it diagnose yet
Old Feb 19, 2010 | 11:07 PM
viciousknid's Avatar
Where's the Beef?
there are multiple threads on this topic. Have you checked any of them for diagnostic information?
Old Feb 20, 2010 | 12:45 PM
budhayes3's Avatar
PT's Slowest Truck
You need a scanner that's capable of retrieving GM ABS codes, a generic OBDII scanner won't do it
Old Feb 20, 2010 | 06:56 PM
slowswb's Avatar
i figured it out it from when i did the gear swap i had it retuned when i had my tuner but i sold it so there no tune but thanks for the tips.
Old Feb 23, 2010 | 09:04 AM
pasadenaman's Avatar
Mine ended up being a bad rear abs or speed sensor. When I was rear ended and got the truck fixed, the light started to turn on. After a 2nd accident a few years later the body shop that they had a list of codes. One was for the rear speed sensor. I have yet to replace it. I have no problems braking. It randomly turns on.
Every friend of mine that has a silverado or gms has the same dang lights on abs.
Old Feb 23, 2010 | 01:25 PM
Where's the Beef?
yea. Sometimes it's the tune, the ABS Sensors, The VSS, the calibration setting, or just a stupid plug under the fuse box.
Old Feb 23, 2010 | 02:36 PM
TXsilverado's Avatar
but chevy wont have a recall for such a common brake problem...
Idryfly5
Sep 2, 2022 08:55 PM
06 4.8
Sep 11, 2015 10:36 AM
MA$TER_E
Sep 9, 2015 03:14 PM
the owl
Sep 4, 2015 04:09 PM
Alco
Sep 4, 2015 04:08 PM
