Blower motor resistor issue
Old 01-08-2008, 06:11 PM
KySilverado's Avatar
Originally Posted by LSUxBlake
Well I decided to troubleshoot things to see exactly where my issue was. When I had everything hooked up, the fuse blew as soon as I turned to position 1. When I disconnected the blower and just left the resistor by itself, the fuse blew when I hit position 4. I disconnected the resistor and left just the harness, and it again blew at position 4. So I'm assuming it's my harness, correct?
If a circuit blows without a load attached to it, it is safe to say there is a short in the wiring or switch.
Old 01-08-2008, 06:17 PM
CHEVRACER83's Avatar
+1 Start Chasing Wires... You Probably Cooked The Harness
Old 07-28-2009, 09:02 AM
man00's Avatar
Just had mine replace at the dealer..total cost was 278.00
Old 07-28-2009, 10:52 AM
foggy's Avatar
just an fyi, you can get the blower resistor and wiring harness for less than $80 at http://store.the-electric-connection...t=products.asp
Old 07-29-2009, 01:22 PM
man00's Avatar
Thumbs up
thanks I wish I knew the GM part number and what the problem was before going to the dealer..Next time I will know..
Old 07-15-2010, 08:17 PM
Registered User
HiddenOkie's Avatar
Angry The Saga Continues 2006 Silverado 3500
My problem is the same as everyone else and it seemed simple enough. So far, we've replaced the resistor thrice, the harness, which was as loose as a rotten tooth, and the blower motor. We still continue to blow resistors. Today, the problem manifested itself as the blower motor would continue to run with the key off. This was the same problem we had when we replaced the resistor the first time. The rest of the time, the thing just went out and burned the harness.
When we replaced the blower motor, our resistor and blower motor no longer ran hot to the touch. Of course, I can't swear to it because of our ungodly heat that's finally arrived, but it seems hot to the touch again in the resistor and on the blower motor after it's run for a while. The guy at the parts counter said to try the cabin air filter. There isn't one that I can find anywhere on the truck. Bad blower motor again? Cheap resistors that keep blowing? We're at a loss and are ready to shoot the thing between the eyes.
Old 07-15-2010, 08:36 PM
PT's Slowest Truck
budhayes3's Avatar
I'd trace the wires to the resistor a little further into the harness, sounds like you have a short somewhere, especially if the motor's running with the key off
*EDIT* Check the wiring to the motor also...
Old 07-15-2010, 09:16 PM
Mrgoodwrench3's Avatar
I have seen many burnt connectors on the back of the control head. Might want to take a look at all the wires and pins.
zblee
63
06-10-2023 01:25 PM
TXsilverado
11-26-2015 10:54 AM
jrplz
07-09-2015 12:07 AM
Quick Reply: Blower motor resistor issue
