Blower motor resistor issue
Old Jan 7, 2008 | 03:12 PM
LSUxBlake's Avatar
Default Blower motor resistor issue
The other day my AC fans stopped working in my 2003 Sierra, and I could smell something burning for about 30 seconds right after it happened. I replaced the resistor under the dash today, changed the fuse that had blown, and immediately upon turning on the AC the fuse popped again. None of the terminals on the harness look burned or melted at all. Any ideas where I should look next?
Old Jan 7, 2008 | 03:24 PM
KySilverado's Avatar
The fan motor or something stopping it from spinning and since you smelled burning all the wiring to the motors.
Old Jan 7, 2008 | 03:48 PM
Chevy Cowboy's Avatar
Piss Pumps for Sale
From: Moncton, New Brunswick, Canada, The True North Strong and Free!
Since I have to check the resister on my blower, to you happen to have pic of where it is at? if you do that would be greatly appreciated
Old Jan 7, 2008 | 04:28 PM
LSUxBlake's Avatar
Here's a pic of the resistor..
And its location, this is with the cover removed. The pic is terrible because of the flash, but you can tell what it is...this is under the passenger dash. Just look for the biggest group of wires.
Old Jan 7, 2008 | 06:58 PM
Piss Pumps for Sale
awsome, thanks alot, I was told that this could be the reason only 2 of my fan speeds work? if it is, will the resistor (the part horizontal across the top?) be burnt?
Old Jan 8, 2008 | 08:41 AM
Hey bro, you need to replace the Resistor's wiring harness too. We got a GM Tech Bulletin on that. The resistor causes a overheat condition and the stock harness is not the proper AWG, and it causes the wires to melt.
Go purchase this part number # 15862656. The bad part is, it's a GM only part number and they retail at $95.00.
I have 7 of them in stock, so if you can't reach satisfaction with your local dealer.....contact me. I'll see what I can do.
Old Jan 8, 2008 | 03:25 PM
Piss Pumps for Sale
ok thanks man, Ill contact you if they give me a crappy price
Old Jan 8, 2008 | 04:06 PM
LSUxBlake's Avatar
Hey, looking at my harness in the pic, doesn't it appear that it's already been replaced? It has crimps on each wire near the plug. I know when I bought the truck and the dealer brought it in for a final inspection before they sold it, they wrote that they had replaced the harness and the resistor.
Old Jan 8, 2008 | 04:11 PM
CHEVRACER83's Avatar
+1 CHANGE THEM ALOT... THE RESISTOR AND HARNESS MOST LIKELY SHOULD GET YOU GOIN
Old Jan 8, 2008 | 04:42 PM
LSUxBlake's Avatar
Well I decided to troubleshoot things to see exactly where my issue was. When I had everything hooked up, the fuse blew as soon as I turned to position 1. When I disconnected the blower and just left the resistor by itself, the fuse blew when I hit position 4. I disconnected the resistor and left just the harness, and it again blew at position 4. So I'm assuming it's my harness, correct?
