Battery Voltage fluctuation?
Not sure what would do this but my alternator charges the battery at 14+ volts as shown on the gauge during a cold start, however after driving the car for a while voltage seems to drop to 12.5ish volts, and goes up to 13.5 if I cruise for a few minutes.
I had a problem on a previous twin turbo Z06 where alternator voltage dropped when the engine heated up, does this make any sense?
The only additional things running on the alt are the TVS water pump (if im not mistaken) and the boost a pump.
is this unusual?
is this unusual?
If this is annoying you and pissing off add on electrical devices like it did in my truck you can unplug the amp load sensor located on the negative battery cable beside the battery under the hood.
This was aggravating my sub amps and was solved once I performed the above mod. It's been two weeks and everything works perfectly and the alternator holds 13.5-15.5 rock solid even with the beat cranked up.
It's normal operation once the bcm determines you are cruising it enters gas mileage mode and shuts down the alternator for better CAFE fuel economy.
A aftermarket alternator will function the same way if it is PCM controlled like the OE unit until the ampload sensor is unplugged.
This is nice to know... I'm going to have the look the fix up. Can you provide a link. I have Viair compressor, and I think it's my evil, and maybe the mod would help.
