Anybody got 02 Serivce manual with Schematics?
Old Nov 3, 2006 | 05:07 PM
Bill Reid's Avatar
Default Anybody got 02 Serivce manual with Schematics?
I need the foot pedal to TAC module circuit scanned and either posted or emailed to me or both... purdy please?
Thanks,
Bill
billreid1@***.net
Old Nov 3, 2006 | 10:33 PM
DrX's Avatar
DrX
Email sent.
I was was just comparing the 02/04/LS2 circuits again the other day. Noticed that a couple of pins from the APP sensors to the TAC module are switched around between the 02 and 04 but the 02 TAC still works on the 04s. APP sensor voltages are supposed to move in the same direction on the 04s but having the high/low ref pins switced around for one of the circuits means that one moves up while the other moves down, which is what an 02 TAC module expects. How lucky was that! The funny thing is that the voltage ranges are supposed to be different on 02s and 04s but it still works?? So now I am wondering if the same can be done with the TP Sensor outputs from the LS2 TB. i.e go back to my 04 TAC module(PCM might be happier with that) but crack open the LS2 TB and separate the high/low reference circuits to the two TPSensors so that they both move in the same direction as expected by an 04 TAC module. Again, the voltage ranges are supposed to be different, but if the 04 APP sensors worked with the 02 TAC module, then perhaps the LS2 TPsensor outputs will also work with the 04 TAC module. I think that the TAC module is supposed to be able to learn the voltage range anyway because it does not always remain constant. Anybody ever crack one of these TBs open?
Old Nov 3, 2006 | 11:25 PM
Bill Reid's Avatar
Thanks Dr X
Obviously you must know what I am trying to do
The 02 TAC input shows 3 APP sensor signals... The 06 only has 2. Does the 04 only have 2?
TP sensors for the 06 TB shows the same resistor configuration (placement in the circuit)... but obviously different from the 02. The 02 TB TP sensor(s) layout shows the same sensor resistor configuration as the 02 TAC APP 1 & 2.
I have an LS2 TB sitting around collecting dust
Bill
Old Nov 3, 2006 | 11:57 PM
DrX's Avatar
DrX
Originally Posted by billreid1@***.net
Thanks Dr X
Bill
Schematics show 3 APP sensors in the 04s. Same as 02s except for the wiring. But "Description and Operation " only mentions 2 sensors for 04s?? I'd say there are 3, as opposed to 2 in the LS2s. Do the 06 trucks have a separate TAC module? Wouldn't mind seeing any 06 schematics that you may have.
Old Nov 4, 2006 | 03:52 PM
DrX's Avatar
DrX
Here's a little more for you to work with. Found some pics of a cracked LS2 APP Sensor. I added the labels for illustrative purposes only. Hi/Low refs and sensor #s could be switched around. I would imagine that the inside of the TB's TP sensor would be similar other than the common hi/low ref circuits in the LS2 TPS. Looks like there is a section of predetermined fixed resistance at one end of each variable resistor/potentiometer. Each sensor also has a different amount of sweep due to the different positions on the arm. These could be part of the differences between a 78mm and 90mm LS2 TB that results in the limiting of max throttle opening to around 85%.
Old Nov 4, 2006 | 04:54 PM
Bill Reid's Avatar
Thanks DrX... right click / save as...time to do some studying.
I would also like to thank Grumpy4.8... for shooting me some emails. Between you 2 guys I have plenty of info to digest now.
Bill
Old Nov 4, 2006 | 05:54 PM
Bill Reid's Avatar
I was wondering about the 3rd APP sensor... as I don't know the rest of the circuit in the TAC module... and how the PCM monitors all 3... if it even monitors the 3rd. I sent you an email of the LS2 but now that I reread everything I think you may already have the LS2 info. I sent the 06 truck schematic... with much thanks to Grumpy4.8. Yes, the 06's have a seperate TAC module. Yes, the 02 TAC plugs right in... just no worky with the LS2 TB. The truck will start and idle but as soon as you go WOT the engine goes into reduced power mode with 3 TPS codes that pop. Hell, I forget... maybe even if the throttle pedal is moved it pops the codes. Here is the thread I started on that one... https://www.performancetrucks.net/fo...eid1%40cox.net
... edit... now that I think about it... I wonder if one of Nick Williams 90mm C5 Corvette throttle body's might work with the 02 TAC. I think the TB motor would hit the side of the Maggie case. But if he flipped the (3) bolt pattern in the CNC program... hmm... or add the 4 bolt LS2 pattern... more thought on that. I have him scoping another solution as well...
Bill
Old Nov 4, 2006 | 10:10 PM
Grumpy5.3's Avatar
your welcome Bill, if there is anything else just hit me up....
can I be nosy???? what are you doing????
Brian
Old Nov 5, 2006 | 12:00 AM
Bill Reid's Avatar
Brian,
Sent you a PM...
Bill
kainzien
Nov 10, 2023 11:37 AM
drummer0415
11
Oct 24, 2015 08:16 PM
91LT16SpeedFormula
Oct 17, 2015 08:01 PM
TAPyvehc93
Sep 12, 2015 08:19 PM
MadDMax66
Sep 5, 2015 01:27 AM
