Anybody does tile work?
Old Jun 14, 2005 | 12:30 AM
FILE's Avatar
Default Anybody does tile work?
I willl placing tile on my patio. It's only about 550 square ft and I will tackling the job. I was looking for a tile cutter but I am clueless as to which one to buy. Can anybody point in me in the right directon.
Old Jun 14, 2005 | 12:31 AM
Let me see what my dad has and ill let you know...........
Old Jun 14, 2005 | 04:47 AM
dkubricht's Avatar
my dad has a "target" wet tile saw. got it at a pawn shop. if everything is set square on it, then it will work great.
Old Jun 14, 2005 | 04:52 AM
quicksilverado's Avatar
You can always rent a tile cutter from Home Depot.
Old Jun 14, 2005 | 05:46 AM
fastazztruck's Avatar
rent one.
Old Jun 14, 2005 | 07:51 AM
Flyer's Avatar
I was told by a pro to use a 4" angle grinder with a handy supply of cutting wheels.
Old Jun 14, 2005 | 09:53 AM
Last Call's Avatar
TOTM: January 2007
What type of tile? Assuming ceramic. Use a wetsaw. I would avoid buying a saw unless your going to be doing this often. You will also want to buy the diagonal cutter to trim pieces around things which are not square.
550 square feet is a lot for a beginner to do in one day unless it is a perfectly flat smooth surface. Renting a saw may cost 40-50 per day. If i were you and were on a budget, I would lay your field one day and measure and mark all of the outside cuts. The next day rent the saw and make your cuts in 1/2 day and save some money.
Don't use premixed acrylic based mortar if its going outside. Use cement based mortar. Mix only half a 5 gallon buck it at a time if it is hot outside. Porbably want to use a 1/4 to 3/8 square notch trowel. Buy at least 3 buckets to clean the drill mixer bit, water, and your mix.
Old Jun 14, 2005 | 10:02 AM
JERRY2500's Avatar
14 Second Truck Club
If it's all strait cuts this is all you need tile cutter I have one and works great
Old Jun 14, 2005 | 10:17 AM
Deckhand's Avatar
I just finished helping my dad lay tile, I highly recommend the MK101 Pro. It cuts the tile easy, and dosent peter out when cutting thick 20" tiles.
Old Jun 14, 2005 | 11:45 AM
FILE's Avatar
Thanks for the advise.... It will ceramic tile and the cuts will be straight. I will post pics when it's all done.
shawn96gmc
May 17, 2016 04:15 PM
Stainless Works
Apr 10, 2016 04:34 PM
Stainless Works
Aug 4, 2015 12:56 PM
atxlt
Jul 20, 2015 11:06 PM
Nimoryan
Jul 5, 2015 03:50 PM
