Any one running ZO6 calipers on an 02 w/18'' wheels?
I don't want to get rid of my 18" Boyd Smoothies up front but need more braking power. I want the ZO6 calipers but I get conflicting info if they will work or not. I hear you really need 15" rotors, who makes them for a stock hub? Has anyone made them work and what exactly do you need.
Thanks troops
Thanks troops
I'm running the Z06 calipers with the 15" rotors and when I had the Gibbs wheels I didn't have much clearance. The clearance was OK with the 14" rotors, but as you mentioned the pad contact area is much better with the larger rotors. Even though there was not full pad contact with the 14" rotors, when the brackets were made for the 15" rotors, they were built to slightly move out the caliper to clear the hat of the bigger rotors. I know every wheel is different, but I just don't see a 18" wheel clearing the calipers with the 15" rotors. Good Luck!
Thanks troops
Thanks troops
plus the wheel weights will hit the caliper cause the rim is so damn close to the caliper i couldnt fit my finger between the caliper and the rim. as for the rotors baer makes them 15 inch pm supersub he'll hook you up with a set the only way to get them to work is with 20s or bigger
Steve-O-08
Apr 19, 2018 09:32 AM
SLOPONY
20
Oct 18, 2016 06:05 AM
mrgrim
Jul 8, 2015 08:12 AM
