AHHHH No oil pressure.. help.
Old May 2, 2011 | 07:28 PM
Default AHHHH No oil pressure.. help.
Sup guys? The other day I started my truck and noticed that it did not build oil pressure for about 30 seconds, then the pressure went all the way up to 80 lbs. after that I saw it at idle around 25-30lbs. This was on my way home. I kept an eye on it and cruising it would not go past about 40lbs under light throttle. I got home and the next day i started the truck and it did not build pressure at all. I have changed the oil filter(mobil1), I also changed the oil pressure switch behind the manifold as well. Still no luck. There is no knock(yet) and the oil in the pan has clean oil(no copper). The gauges do go down to zero when I start the truck, so I think that they are working properly. Does anyone have any ideas? What should I do next? Any help would be greatly appreciated... Thanks.
Old May 2, 2011 | 07:29 PM
iamkeniff's Avatar
oil pump going out?
Old May 2, 2011 | 07:35 PM
Originally Posted by iamkeniff
oil pump going out?
It's an 04 with 44,000 on the clock. I might just have to bite the bullet and change it. It's just alot of work to do if im not sure that it's the problem. Other than that, I dont know what else it could be.
Old May 2, 2011 | 07:51 PM
68haywagon's Avatar
Try hooking a manual gauge up to verify? Could be the the motor is going out on the cluster?
Mike
Old May 2, 2011 | 08:02 PM
Mike
I'm going to borrow one tomorrow. I thought about that too, but when I turn the key, The gauge resets itself. I'm going to look into that after I check the pressure with a manual gauge. Thanks.
Old May 8, 2011 | 11:51 AM
Problem solved. After about $140 worth of things that I replaced, I found That there was an electrical short. It's fixed now. Thanks for the help.
Old May 8, 2011 | 12:01 PM
00ChevyScott's Avatar
Wearin' da big hat
Ya I was going to say I doubt it was the oil pump. You would've heard it and the engine would have definitely sounded different.
Old Nov 1, 2011 | 02:11 PM
robbyredneck's Avatar
where?
Old Nov 1, 2011 | 04:39 PM
1SICKhawk's Avatar
i can assure you its the gauge, or the sending unit, id be really suprised if it was the pump.
Old Nov 1, 2011 | 04:41 PM
1SICKhawk's Avatar
Dirt digger, can i ask you something? When it would bing to high or low, could you hear it? If that makes sense...Like when mine did it i could hear like an electrical type surge, crazy i know.
lukn4trbl355
Oct 21, 2015 11:19 PM
Wrecker 426
Sep 30, 2015 09:39 PM
sTNT971
Sep 26, 2015 04:22 PM
lxcoupe
Sep 25, 2015 12:36 PM
SWINGRRRR
Sep 3, 2015 07:49 PM
