6.0 4l80e swap won't start
Old Mar 20, 2009 | 03:26 PM
brent5631's Avatar
Default 6.0 4l80e swap won't start
okay guys i just got the new motor and trans in. i topped off all of the fluids and tried to start it but it just cranks and cranks.
Its got fuel pressure and spark and the neutral safety switch is working correctly.
so does anyone have any other ideas?
i'll go check the grounds again but i think they are all right.
advice please
Old Mar 20, 2009 | 03:38 PM
so are you stil running the stock computer?
Old Mar 20, 2009 | 03:40 PM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
You need to get your PCM tuned.
Old Mar 20, 2009 | 03:56 PM
brent5631's Avatar
no, i got a wheatley tune in there right now.
all of the grounds look and feel tight.
i'm not showing any code on the handheld
and i'm getting spark on both sides and fuel pressure to the rail.
anything else i missed
Old Mar 20, 2009 | 04:17 PM
nonnieselman's Avatar
crank sensor? cam sensor?
Old Mar 20, 2009 | 04:28 PM
brent5631's Avatar
they are both connected but how would i go about seeing if they are bad?
the spark plugs are pulsing so wouldn't that mean that they cam or crank sensors are working.
Old Mar 20, 2009 | 04:34 PM
on Silver-mod-o's truck we couldnt get his to crank, he replaced the crank sensor and vola!!
Old Mar 20, 2009 | 04:39 PM
brent5631's Avatar
is the crank sensor the one under the starter?
Old Mar 20, 2009 | 04:46 PM
yeps!
Old Mar 20, 2009 | 04:48 PM
Wheatley's Avatar
Truck Sponsor
I disabled your VATS also,so that is not the problem,so there is a problem elsewhere.
