5.3L engine trouble HELP
Old Feb 11, 2012 | 11:03 AM
greasemykey's Avatar
Default 5.3L engine trouble HELP
i have a 2000 silverado 5.3 2wd. engine has 50K on it.i have had no issues until i installed the 90mm throttle body and TBSS intake. last night i was driving my truck to a friends house and i got to the stop light and the engine died. i started it and it was a hard start. i have been having vacuum leak issues so this was no surprise. it finally starts and i hear the worst metal on metal sound. it sounds like a spun rod bearing. but here is the kicker that has me confused. if i spun a rod it should be firing that cylinder. but the engine is shaking and backfiring like its not running a few cylinders and the metal sound is off and on but the misfire is constant. im beginning to lean toward a broken rocker or valve spring. any thoughts?
Old Feb 11, 2012 | 05:26 PM
Vince B's Avatar
Moving this to the correct section.
Old Feb 11, 2012 | 05:46 PM
sorry about that.
Old Feb 11, 2012 | 08:36 PM
pulled the valve covers and all valves and springs are in the correct spots. im going to pull the pan tomorrow and check for a busted piston skirt or some other damage.
Old Feb 11, 2012 | 11:18 PM
Suburbazine's Avatar
Vacuum issues? Maybe you ran a cylinder too lean and burned it up?
Old Feb 12, 2012 | 12:04 AM
would i get a clattering noise if i burned up a piston?
Old Feb 12, 2012 | 08:36 AM
mcfarlnd's Avatar
Un-Registered User
sorry, that is not good.... Can you get a video of it?
Old Feb 12, 2012 | 09:27 AM
Nflddog1000's Avatar
Why didn't u fix the vacuum leak ? Maintenance is a big factor that a lot of people forget to but the most important one
Old Feb 12, 2012 | 10:57 AM
i had been working on it. i was driving it to see if it was fixed. figured i would pick up my tools across town while i was at it.
Old Feb 12, 2012 | 01:52 PM
TXSZ66AVLANCHE's Avatar
This is what a burned piston looks like, rev up the engine and it sucks up oil. Click on picture for video...
