5.3L engine trouble HELP
i have a 2000 silverado 5.3 2wd. engine has 50K on it.i have had no issues until i installed the 90mm throttle body and TBSS intake. last night i was driving my truck to a friends house and i got to the stop light and the engine died. i started it and it was a hard start. i have been having vacuum leak issues so this was no surprise. it finally starts and i hear the worst metal on metal sound. it sounds like a spun rod bearing. but here is the kicker that has me confused. if i spun a rod it should be firing that cylinder. but the engine is shaking and backfiring like its not running a few cylinders and the metal sound is off and on but the misfire is constant. im beginning to lean toward a broken rocker or valve spring. any thoughts?
sorry, that is not good.... Can you get a video of it?
