4L80/ driveshaft ??
Old Dec 3, 2014 | 08:22 PM
N/ALS1's Avatar
Default 4L80/ driveshaft ??
I'm swapping to an 80e and was wondering do I need to swap my driveshaft for an aftermarket one or should I just cut mine down. I have a '00 Chevy rcsb with a 6.0 swap. The reared will be getting tru trac and 4.10's.
http://www.driveshaftspecialist.com/...uckmaster.html has the ds-1 for $245- $315. Thanks for the help.
Old Dec 4, 2014 | 10:15 PM
N/ALS1's Avatar
No one has any input?
Old Dec 5, 2014 | 11:31 AM
shupe's Avatar
Truck Driveshafts master page has the ds-1 for $245- $315. Thanks for the help.
IIRC we took off an inch off the driveshaft on my crewcab when doing the 80e swap.
Old Dec 5, 2014 | 11:48 AM
03sierraslt's Avatar
I had mine cut down, but I already had a 6" driveshaft specialist Dshaft. Are you 2wd?
Old Dec 5, 2014 | 11:55 AM
javzh's Avatar
i didnt cut anthing off my rcsb. just swapped yoke.
Old Dec 5, 2014 | 11:57 AM
Thats what I am getting at if he is 2wd. TH400 yoke is shorter.
Old Dec 5, 2014 | 12:34 PM
10 Second Club
Same here, didn't even require a trick u joint.
Old Dec 5, 2014 | 09:04 PM
N/ALS1's Avatar
Yeah it's 2wd, which yoke should I get.
Old Dec 6, 2014 | 07:09 AM
10 Second Club
IMG_20141101_102738403_zps1a3504a5.jpg Photo by Bz2886 | Photobucket
This is what is in my truck. Not sure on a part # or vendor. The part that slides into the transmission is just over 5" long.
Old Dec 6, 2014 | 07:21 AM
What size u joints are on your driveshaft?
http://www.actionmachineinc.com/ujoi...ringguide.aspx
I believe all TH400 tailshafts are made for 1350.
