2005 door buzzer?
Old Aug 2, 2005 | 09:14 PM
TJ's Avatar
TJ
Default 2005 door buzzer?
ive noticed its comming from the front speaker, and not a lil black box i can unplug like ive done on vehicles in the past.
is there ANY fix for this other than ear plugs?
i like jamming out while i clean my truck, and its driving me crazy.
Old Aug 2, 2005 | 09:27 PM
jerome's Avatar
dont leave key in ignition and have door open.
Old Aug 3, 2005 | 05:42 PM
TJ's Avatar
TJ
ummmm thanks.
i was gonna pull fuses, but didnt see any directly related to a door buzzer, nor anything close.
Old Aug 4, 2005 | 08:33 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Sure you can. Turn the key to the on position press the dome override so the dome light isnt on and listen away I do it all the time and havent had a problem.
Old Aug 4, 2005 | 09:40 AM
ap2002's Avatar
I know there is a way cause my 04 did that and then after I installed a amp and speakers and it was louder people a block away could of probably here it then.... but I took it back to my buddy that hooked it up and he did not know how at first but ended up figuring it out.... I try to get in touch with him to see if he remembers...
Old Aug 4, 2005 | 10:28 AM
LOW2000's Avatar
Its because the signal comes from the radio, same as onstar.
Old Aug 4, 2005 | 08:05 PM
TJ's Avatar
TJ
ill have to try that in the morning.
thanks!
something so simple.
Old Aug 5, 2005 | 02:15 AM
thunder550's Avatar
High on diesel fumes
Click the latch closed on the door when it's open, then you don't have to have the truck in Run, only have to turn the key to Accessory. Just don't forget to open the latch before you shut the door.
Old Aug 5, 2005 | 06:21 AM
1slow01Z71's Avatar
Oh yeah forgot about that one that works too.
Old Aug 5, 2005 | 02:44 PM
TJ's Avatar
TJ
thanks!
i tried it several ways with the key off, accessory, holding my mouth different ways, nothing worked.
dome override is a no go on my 05 2500hd.
