2005 door buzzer?
ive noticed its comming from the front speaker, and not a lil black box i can unplug like ive done on vehicles in the past.
is there ANY fix for this other than ear plugs?
i like jamming out while i clean my truck, and its driving me crazy.
Originally Posted by jerome
dont leave key in ignition and have door open.
i was gonna pull fuses, but didnt see any directly related to a door buzzer, nor anything close.
I know there is a way cause my 04 did that and then after I installed a amp and speakers and it was louder
people a block away could of probably here it then.... but I took it back to my buddy that hooked it up and he did not know how at first but ended up figuring it out.... I try to get in touch with him to see if he remembers...
Sure you can. Turn the key to the on position press the dome override so the dome light isnt on and listen away I do it all the time and havent had a problem.
thanks!
something so simple.
Click the latch closed on the door when it's open, then you don't have to have the truck in Run, only have to turn the key to Accessory. Just don't forget to open the latch before you shut the door.
Originally Posted by TJ
ill have to try that in the morning.
thanks!
thanks!
dome override is a no go on my 05 2500hd.
