2005 door buzzer?
Originally Posted by TJ
i tried it several ways with the key off, accessory, holding my mouth different ways, nothing worked.
dome override is a no go on my 05 2500hd.
Originally Posted by CAMMIN03'
Is there a wire in the back you can cut.... My parking brake sensor is out and it dings all the time....
What wire in the back of the radio controls that???
ill post up if i find anything.
Sick of the door chime or seat belt chime, there is a fix. There is a plug under the drivers seat, just unplug it. Make sure you trace it to the seat belt if your truck has power seats or heated seats. I found a link about the door chime http://www.silveradoss.com/forums/in...&hl=chimes
I did mine and its all gone, the hardest part is getting the wire out of the plug. The wire can be released from the other side with a small nail, you will see a small brass color tab. Just hold it to the right side of the plug and it should just slide out. The guy is trying to release the wire from the wrong side of the plug in the pics. Just try it you will see.
RS/SS 4.8
Sep 17, 2015 09:17 PM
