2002 Chevy running lights.....
#22
I'm not 100% sure what size resistor, but there's a way to find out....unplug the connector to the BCM that houses those 2 wires, make sure that it is bright out, and check the resistance across those 2 wires with an ohm meter. I'm sure that a resistor will be just as good if not better...I just went with an LED since it was a "diode", much like the photodiode that changes resistance with the brightness of light. I just picked an LED that was slightly off. When my lights do accidentally come on by themselves, I can actually reach under the dash and touch the LED for a few seconds and the heat from my hands warms it up enough to turn the lights off lol.
If you do use a diode, it must be wired in correctly, positive to grey, negative to white I believe. If you use a resistor, make sure that it's insulated as it will generate heat...as little as it may be.
#25
With the correct resistor you will not need to reach under there...it just happened to me the other day actually. I plan to eventually check the resistance myself and get the correct resistor or LED, but since the "accidental auto on" only seems to happen a few times a year, it hasn't bothered me that much.
bsgiffor
Jul 19, 2015 11:14 AM
