How many CFM on OEM efans?
Old Dec 6, 2007 | 01:35 AM
blue widow's Avatar
Default How many CFM on OEM efans?
Like the title states. does any one know how many CFM the OEM 34" 05+ efans flow? I would like to know if it is more worth while to go with a higher flow aftermarket fan/shroud setup as opposed to the OEM version. If they are roughly the same the only advantage I can see with going custom would be slightly more room for the turbo system in the works.
Old Dec 8, 2007 | 12:05 PM
Truckshop's Avatar
do not know the specs but i see no advantage unless you need the extra room.
Old Dec 11, 2007 | 08:11 PM
99Silver6.0's Avatar
The OE fans pull a dam good amount of air when they kick to high!!! Trust me!!
Old Dec 11, 2007 | 08:15 PM
nonnieselman's Avatar
I have LT1 fans with new motors... they hardly ever come on..
but i can override the PCM with mini switchs and they move alot of air!!
It will pull your shirt to the grill if you walk close to it..
Old Dec 12, 2007 | 07:17 PM
TURBHOE's Avatar
yeah, the stock truck fans will too. not sure how much but i know its alot.
Porscharu914
14
Jan 20, 2016 10:45 AM
Closer_2001
Sep 24, 2015 09:15 PM
Parriott31
Sep 22, 2015 08:44 PM
Velocity1
Sep 22, 2015 01:32 PM
dirt track racer 81
Sep 21, 2015 06:44 PM
