2002 Chevy running lights.....
Old Dec 10, 2007 | 09:15 PM
  #21
Blue02Hoe's Avatar
Originally Posted by 06crew
just break the sensor on the dash thats what i did......
how and where is the sensor that you broke?
Old Dec 10, 2007 | 09:19 PM
  #22
YenkoST's Avatar
I'm not 100% sure what size resistor, but there's a way to find out....unplug the connector to the BCM that houses those 2 wires, make sure that it is bright out, and check the resistance across those 2 wires with an ohm meter. I'm sure that a resistor will be just as good if not better...I just went with an LED since it was a "diode", much like the photodiode that changes resistance with the brightness of light. I just picked an LED that was slightly off. When my lights do accidentally come on by themselves, I can actually reach under the dash and touch the LED for a few seconds and the heat from my hands warms it up enough to turn the lights off lol.
If you do use a diode, it must be wired in correctly, positive to grey, negative to white I believe. If you use a resistor, make sure that it's insulated as it will generate heat...as little as it may be.
Ok..I might probe them and get the results and see what we can do...I'd rather not reach under the dash when I want them off...I can pressure the button 4 times but it gets old.
Old Dec 10, 2007 | 09:29 PM
  #23
00Silv4.8's Avatar
Hey, YenkoST, just let me know when u figure out what kinda resistor it takes cuz I have the same mindset haha and I dont have an OHM on hand so ur findings would be awesome. Thanks man
Old Dec 11, 2007 | 10:40 AM
  #24
Tootall's Avatar
50-100 and a dealer can reprogram the BCM
Old Dec 12, 2007 | 07:05 AM
  #25
budhayes3's Avatar
PT's Slowest Truck
With the correct resistor you will not need to reach under there...it just happened to me the other day actually. I plan to eventually check the resistance myself and get the correct resistor or LED, but since the "accidental auto on" only seems to happen a few times a year, it hasn't bothered me that much.
Old Dec 12, 2007 | 03:43 PM
  #26
YenkoST's Avatar
I haven't had time to mess it with yet...going to probe them on Saturday.
Oobray
Jun 13, 2022 03:38 AM
stealthperf
34
Feb 14, 2016 11:35 AM
bsgiffor
Jul 19, 2015 11:14 AM
signguy62
Jul 16, 2015 05:43 PM
ChevyLee
Jul 10, 2015 10:56 PM
