105 to 145 amp alt.
Old Oct 12, 2005 | 10:31 AM
wkdivr's Avatar
Default 105 to 145 amp alt.
Alright, before I get too far into it. Just checking. The 145 is a direct replacement for the 105, right? What about belts?
Old Oct 12, 2005 | 10:38 AM
moregrip's Avatar
what a rush!
if your running your 112.5" radix belt you should be fine, of course thats not a gaurantee.
Old Oct 12, 2005 | 10:41 AM
1SlowHoe's Avatar
Destroyer of Transmissions
I seem to remember NakedAV having issues with the plug not matchimg. 4 wires instead of 3. Not sure.
Old Oct 12, 2005 | 12:02 PM
Mr. Sandog's Avatar
My issue was with the 160A Tahoe Police Package alternator. AFAIK, there are no issues with the 145A alternator, P/N 10464476, except that you may require a slightly longer belt (but maybe not).
Old Oct 12, 2005 | 12:16 PM
wkdivr's Avatar
Thanks, guys. I forgot I even had it. I just ran across it in the garage! Yeah, I'm running the 112.5" belt that came in the Radix kit. I think I'm going to try a Gatorback belt, just for the hell of it.
Old Oct 12, 2005 | 12:55 PM
1SlowHoe's Avatar
What are the advantages for running a bigger Alt?
Old Oct 12, 2005 | 01:11 PM
wkdivr's Avatar
I'm going to run the ls1 electric fans, and maybe a switch to let my coolant pump on my Radix run for a short time after I shut the key off to let the intercooler coolant cool down on real hot days at the track.
Old Oct 12, 2005 | 01:50 PM
Mr. Sandog's Avatar
You need it when increasing current draw on your system. Electric fans draw big current. I don't think you'll find a full size GM truck with e-fans that doesn't have a 145A alternator. Next to e-fans, certain stereo setups (ones with larger amps) also need more power.
Old Oct 12, 2005 | 02:04 PM
budhayes3's Avatar
PT's Slowest Truck
Here's some info that might help: https://www.performancetrucks.net/fo...+official+2005
Old Oct 12, 2005 | 08:56 PM
nativetexan's Avatar
13 Second Truck Club
Just curious. I'm about to put the '05 truck fans on my '04. Do the '05s with the efans come with a 145 amp alternator? I have just the stock load now and with the additional load the efans will place, should I be upgrading? I may wait and see if I have a problem.
