105 to 145 amp alt.
Alright, before I get too far into it. Just checking. The 145 is a direct replacement for the 105, right? What about belts?
I seem to remember NakedAV having issues with the plug not matchimg. 4 wires instead of 3. Not sure.
Thanks, guys. I forgot I even had it. I just ran across it in the garage! Yeah, I'm running the 112.5" belt that came in the Radix kit. I think I'm going to try a Gatorback belt, just for the hell of it.
What are the advantages for running a bigger Alt?
I'm going to run the ls1 electric fans, and maybe a switch to let my coolant pump on my Radix run for a short time after I shut the key off to let the intercooler coolant cool down on real hot days at the track.
Here's some info that might help: https://www.performancetrucks.net/fo...+official+2005
Originally Posted by Naked AV
You need it when increasing current draw on your system. Electric fans draw big current. I don't think you'll find a full size GM truck with e-fans that doesn't have a 145A alternator. Next to e-fans, certain stereo setups (ones with larger amps) also need more power.
