10 bolt brake help
Old Oct 31, 2011 | 07:38 PM
LS-Powered's Avatar
Default 10 bolt brake help
its come time to rebuild my 10 bolt rearend
the brakes are it bad condition esp. the drum in hat (emergency brake) setup
i was wonderin if anybody knows of a disc brake setup that bolts up to the exsisting holes
thanks
Old Nov 10, 2011 | 04:45 PM
ayousef's Avatar
bump. my truck has 15" brembo GTs in the front and drum brakes in the rear, so I can use this piece of information too!
Old Nov 10, 2011 | 04:56 PM
1FastBrick's Avatar
Custm2500's Rude Friend
The factory ones 99-04. Bear Brakes also has a kit.
Be fore warned that you may need a porpotion valve on drum brake equiped trucks beacuse drum shoes need more pressure then disc callipers to apply...
Old Nov 11, 2011 | 09:53 AM
Silverado777's Avatar
I just swapped to an axle that already has disc brakes. The braking is so much better and I didn't change the valve. Parking brake blows though....
Old Nov 11, 2011 | 10:56 AM
1FastBrick's Avatar
There is no individule Valve. Pressure is controlled at the ABS pump manifold.
I Helped some one do the swap on an 06 crew cab V-max and the rears were nearly locking up under hard brakeing condition. A Gm Dealer Won't flash the ABS unit because of Liabilty. After talking with some people in the Brake industry the solution was to install an after market porportioning valve that can be manualy adjusted.
Glad to See your swap went well. Its worth it In my opinon Too! I have an 00 Wich was 4 wheel disc from the factory. I am going to upgrade to 05- up Larger fronts, add hydro boost and run the twin piston calipers off an SUV in the rear.
Old Nov 11, 2011 | 10:58 AM
EVILGMC's Avatar
i am running the hydroboost with 05 fronts and suv rears...stops great and a vastly improved pedal feel. best bang for the buck by far.
Old Nov 11, 2011 | 11:06 AM
1FastBrick's Avatar
The Garage Queen Runs...
Old Nov 11, 2011 | 12:14 PM
I have a set of slightly used 13'' EBC slotted and dimpled rotors and calipers for sale if anyone is interested.
Old Dec 22, 2011 | 11:50 AM
LS-Powered's Avatar
for 10 bolt rear?
5.3Okasai
Mar 9, 2022 01:07 PM
vipergtrdj
Aug 6, 2015 10:19 PM
1320Chicken
Jul 14, 2015 10:58 PM
mrgrim
Jul 8, 2015 08:12 AM
