06 chevy brake problems Im stumped
Old Apr 23, 2010 | 05:57 PM
CashDudeHomie's Avatar
Yeah just pop the pins out of the rubber boots and coat them with brake grease. Mine were bone dry and starting to rust!
Old Apr 23, 2010 | 07:34 PM
If you can make it do immediately crack the lines at the master cylinder. If you have fluid come out with pressure then you are looking at either a master cylinder that has gone bad or an abs unit. Ran into this before on a couple of different trucks at the shop. One time it was a master about a year later had another truck through and it was the ABS unit. Sometimes if you can get it to not act up for a bit and it is the abs unit you can panic stop it from 45-50 to zero with your foot buried to the floor several times and it will solve the problem. It cycles the valves and solenoids internally during an abs stop and it will clear debris if it is an obstruction causing your problem.
Old Apr 25, 2010 | 12:36 AM
1fastmofo's Avatar
on this 06 the pads sat on a silver metal tab so i removed then and greased em with the high temp silecone they sell by the parts store register. seems to have fixed the problem thanks for all the replys everyone
Old Apr 25, 2010 | 12:39 AM
budhayes3's Avatar
PT's Slowest Truck
Cool deal man, sounds like the pads were definitely binding, glad that you got it fixed
ARC
57
Feb 21, 2022 10:54 AM
Corvette454l88
Sep 1, 2016 01:24 AM
black03rcsb
Sep 1, 2015 10:17 AM
dry_kill
11
Aug 28, 2015 09:53 PM
05GMC4.8
Aug 7, 2015 09:55 PM
