05 electric fan swap
Old Jun 30, 2005 | 11:31 PM
JT-bo's Avatar
Default 05 electric fan swap
i just saw a buddies new 05 sierra and i'm jealous. I was stunned to see the new trucks come electric fans and i am wondering if its easy to put on in my 02 sierra? Anyone done it yet?
Old Jun 30, 2005 | 11:37 PM
OCBC's Avatar
SEARCH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! IS it working yet?
Yes, it can be done, you need alot of stuff, search, its here.
Old Jul 1, 2005 | 12:09 AM
JT-bo's Avatar
Nope not yet. I'm new give me a break huh?
Old Jul 1, 2005 | 12:24 AM
BlownChevy's Avatar
blownerator
25 Year Member
it is possible and easy. I have done the swap myself and it was pretty simple, just need to spend about 500 bucks to do it.
Old Jul 1, 2005 | 02:49 AM
thunder550's Avatar
High on diesel fumes
You need a 34" radiator, a set of factory e-fans, a harness, an extra set of radiator bolts, and a PCM tune to turn the fan feature on if you have the fans controlled by the PCM. My grand total was about $500 like BlownChevy said. The swap itself is very easy and straightforward. The hardest thing for me was dealing with all of the coolant that didn't come out when I drained the radiator. Made a big ole mess on the garage floor.
Old Jul 1, 2005 | 07:19 AM
budhayes3's Avatar
PT's Slowest Truck
thunder550 pretty much summed it up, it's a piece of cake. You also have to trim back the rubber flaps along the sides of the radiator to accomodate the bigger radiator...takes 5 mins. Also, if you have a K&N FIPK you'll have to modify the heat shield for fitment with the 34" rad.
Old Jul 4, 2005 | 11:29 PM
JT-bo's Avatar
Thanks guys, it doesn't sound hard at all.
Old Jul 4, 2005 | 11:53 PM
99Silver6.0's Avatar
Just get some LS1 fans and a harness from Allen Nelson. Fuckload cheaper and work just as good.
Old Jul 5, 2005 | 10:51 AM
04BlackSilverado's Avatar
Does anyone have the P/N for the rubber flaps for the 05 34" radiator? or any of the 34" rad trucks like the 2500's?
Old Jul 5, 2005 | 01:07 PM
tdrumm's Avatar
Just cut 'em, all you need is sissors or a utility knife.
