04 Denali, Cranks a while before starting
Old 08-11-2018, 12:57 PM
mhorn0817's Avatar
Not sure exactly where the smell is comin from because i cant smell. My wife says all over...front, back, inside so im not sure
Old 08-12-2018, 10:39 AM
RB04Av's Avatar
I had a fuel pump in my truck to leak, where the return line goes into it... got to where gas was pooling up on top of the tank and dripping off, when it was running.
Thank you GM for making that out of material that rusts and can leak fuel by the gallon and is only about tinfoil thick. Right on up there with the brake lines. (which also have rusted through and failed on my truck)
Old 08-12-2018, 12:09 PM
MikeGyver's Avatar
Let's start a class action lawsuit. GM knowingly endangered us with brake, fuel, and transmission lines guaranteed to fail. I, too had brake lines fail, and my trans cooler lines are about to go. I'd like to see Boeing try to get away with using such inferior materials on a passenger plane.
Anyway, a fuel return line leaking wouldn't cause long crank-to-start times from fuel pressure bleed down.
Old 08-12-2018, 10:02 PM
TurboJohn6's Avatar
The description of your problem sounds more like a bad fuel pressure regulator to me. Pull of the vacuum hose to the regulator and see if any fuel comes out. If there is any fuel there, the regulator is your problem and the cause of the fuel odor.
Old 08-13-2018, 08:57 AM
mhorn0817's Avatar
Its a 04 so the fpr is in tank with the pump. Symptoms point to bad fpr but the smell doesnt. I cant smell so im relying on others to tell me where. And they smell it front and back
Old 08-13-2018, 12:43 PM
11 Second Club
MrHorsepowerLSx's Avatar
Crawl under the truck and start looking around for an Evap line with a crack in it. Check the fuel
filter connections. Check the flex hoses at the fire wall for the fuel rail, check the gas cap.
Check on top of the fuel assembly for a cracked connection.
Have you installed a fuel pressure gauge by any chance
Old 08-13-2018, 07:49 PM
mhorn0817's Avatar
Ok so i put a FP gauge on it to test it. Truck sat for a hour, i turned the key and fp went to 15, off and on again and went to 40, off and on again and went to 55. Let it sit and it dropped to 30 in about 1 minute. Stared the truck and jumped and stayed at 60. Turned it off and dropped to 30 in a minite, 20 in 2 minutes, 10 in 10 minutes.
Also my brother said the smell is strogest under the truck by the tank. I had him cycle the key on and off while i laid under it and as the truck would prime i could hear a whoosh sound like pressure was being let off, not sure if thatd normal or not.
So im guessing ill just have to start with replacing the pump assembly and go from there
Old 11-18-2018, 07:39 PM
mhorn0817's Avatar
It was the fuel pump assembly. The lines coming off of top of fuel pump assembly was rusted and leaking , causing gas smell and hard to start. Needed to replace plastic lines going to fuel,pump assembly because they were all rusted and broke off
Old 11-19-2018, 07:20 AM
wretched73's Avatar
Thanks for posting an update!
Old 11-19-2018, 07:55 AM
RB04Av's Avatar
I had that exact same thing happen to my 04 Av... the top of the pump, where the return line goes back in, and the line itself, rusted through; and gas was literally pooling up on top and dripping off the tank.
Thank you GM for saving $.0037 and using mild steel instead of stainless for that part. About 3 sq in of 26 ga metal. And of course, all the fittings that those plastic hoses hook to was all so rusted up I couldn't get those off, and had to buy a set of those too.
Just like the brake lines on that truck, which also rusted through, and one popped one day while I was pulling a trailer down a busy street. Thank goodness I was able to miss the cars at the traffic light I was coming to and turn into a parking lot. A FULL SET of mild steel lines was $76 or so; a FULL SET of stainless ones was $108 or thereabouts, RETAIL. Thank you GM for saving acoupla more pennies there and risking killing somebody.
Pretty sure I'll be needing to replace the fuel lines before the pressure one pops and sprays the underside of the truck and the rest of the world with gallons of gasoline before I can do anything about it.
mhorn0817
11-06-2016 12:14 PM
06sierra5.3
08-03-2012 09:31 PM
Phatchevy
07-19-2005 11:33 PM
Slammedchevy01
17
05-04-2005 03:02 AM
Quick Reply: 04 Denali, Cranks a while before starting
