04 Denali, Cranks a while before starting
Last week my truck started cranking longer before starting but does eventually start and runs fine. If i turn it off and start it right back up then it fires right up. If it sits a while then seems like it loses pressure maybe and cranks longer. Could this be fuel pressure regulator? 04 denali, intake and w4m tune
Also, wife says theres a bad gas smell. No visible leaks though
Any check engine lights on |
No lights
To answer your question, yes it could be a bad fuel pressure regulator.
Crank position sensor also has that effect
Would a CPS cause fuel smell and start back up right away if it doesnt sit too long?
Yes it could but im no expert its just my opinion i had it happen on a Cadillac i had
Where is the fuel smell coming from? Tailpipe, Underhood, in the cab? |
Fuel line have a pin hole in it? Rusty state? |
