'00 5.3L Crankshaft Serp Belt Slight Wobble?
Old Apr 10, 2014 | 04:24 AM
Velocity1's Avatar
Default '00 5.3L Crankshaft Serp Belt Slight Wobble?
Last evening my serp. belt tensioner/pulley let go and chewed up the belt. Into a friends garage and an hour later I'm back on the road. No big deal.
The odometer shows a tick less than 148k miles but we've been able to research the truck origin and see where the long block was replaced under warranty early in life and has 80-85k miles on it.
While observing the new belt and tensioner operation, we noticed what I'll define as a slight wobble to the crank pulley. Not like it's about to come out the bottom, but a noticeable runout or wobble, (enough to get your attention).
My Citizen watch makes more noise than this motor when running even after a cold start up and less now that the pulley and belt has been changed. I've owned the truck for the last 8 years, have never had a problem. Getting ready to overhaul the topend with the Texas Speed 212/218 cam kit so the crank balancer and pulley will be coming off anyhow.
Am I overly concerned? I've never noticed this before but I've never looked for it until last night.
Thoughts?
Thanks!
Old Apr 11, 2014 | 10:34 AM
Velocity1's Avatar
anybody?? I'm looking at a new under drive crank harm balancer/pulley and an alternator overdrive pulley.
Appreciate all thoughts and comments.
Thanks, Dave aka V1
Old Apr 11, 2014 | 11:03 AM
Atomic's Avatar
I have a gauge for that
Take the belt off and run it for a few seconds to see if you still see the pulley wobbling. Check to make sure the bolt is tight as well.
Old Apr 11, 2014 | 01:47 PM
Velocity1's Avatar
Thanks for the reply. My thinking as well. I realize the crank harm. balancer/pulley bolt is a torque to yield bolt, but snugging it for a relatively short period of time is better than loose if that's the issue.
Getting ready to disassemble the whole top end for heads, cam, pump, t-gear/chain set etc.
V1
Old Apr 11, 2014 | 04:35 PM
BigKID's Avatar
Being that the truck is 14 years old, the elastomer separating the two parts of the balancer could be deteriorating. I recently replaced an ASP underdrive pulley that had this happen and I have heard of stock crank pulleys doing the same.
Old Apr 11, 2014 | 08:20 PM
Velocity1's Avatar
Sounds reasonable. I had a Boss 302 motor in a boat of mine once that actually spun the ring enough that I couldn't set the timing. May just have to order an under drive replacement.
Thanks!
Old Apr 15, 2014 | 12:19 AM
1FastBrick's Avatar
Custm2500's Rude Friend
My 00 has always had a little wobble and it's never been an issue.
Old Apr 15, 2014 | 08:07 AM
black00chev's Avatar
Slowest turbo build ever!
Glad to hear this! I noticed mine doing the same thing ever since I put my efans on and could see all the way down to the crank pulley.
old motorhead
Sep 29, 2015 08:22 PM
murderedSS
Sep 27, 2015 10:16 PM
sTNT971
Sep 26, 2015 04:22 PM
97_ek
Sep 23, 2015 09:16 PM
Forcefed81
Sep 8, 2015 10:02 PM
