your thoughts on the fast 92mm intakes
Old Mar 16, 2009 | 08:54 PM
  #21
sickREDsierra's Avatar
i agree. lots of speculation with no interpretation. nation. station. alienation.
sorry . i was on a roll there.
Old Mar 16, 2009 | 08:59 PM
  #22
dirt track racer 81's Avatar
Vic Jr. with a 1200cfm 4 barrel throttle plate with a carb style nitrous plate is what im saving up for.. I think this would be the cheapest route for what im wanting to do with a 200-250 shot instead of running a fast intake with a direct port to run the same shot of nitrous
Old Mar 16, 2009 | 09:37 PM
  #23
Phantom's Avatar
11 Second Club
You need to save for a good trans before an intake!!!
Old Mar 16, 2009 | 11:24 PM
  #24
If he has an LS6, then my freaking truck one will outflow it.
the ls2 90mm will definitely outflow it, and broaden the torque, and give it a great low-end torque gain.
Old Mar 17, 2009 | 12:46 AM
  #25
TXsilverado's Avatar
i have an awesome nitrous setup IMO...
2 10 lb bottles, nx wet kit good to 250 shot, nx purge, nx bottle heater, nx bottle blanket, nx bottle opener, nx bottle heater controller, nitrous outlet nitrous plate, nitrous outlet nitrous switch panel, fjo progressive controller, fuel pressure safety switch, wot switch and more crap im probably forgetting about.
its all sitting in a box in my garage. its been there for about 2 years now. my nitrous times dont get me as excited as my N/A times. when i do spray its coming out of the hole progressive and im starting with a 150 shot. i still need to upgrade my fuel pump to get the nitrous going.
ive also seen dyno graphs where the stock fast 92mm matches the factory hp and torque down low until about 3500 rpm where the torque and hp pull away from the ls6 all the way to redline. i dont give a damn about 3500 and below because my truck is never there on the track unless im sitting at the line stalling up. from then on its between 5300 and 7000 rpm.
Old Mar 17, 2009 | 07:48 AM
  #26
tarinitup's Avatar
9 Second Truck Club
I droped .7 and gained 5 mph with fast 90 and stall. Pretty sure stall made most of the difference but I'm sure the Fast helped too.
Old Mar 17, 2009 | 10:33 AM
  #27
can i see the two time slips? im sure the stall helped the most, but gaining 5mph is extreemly impressive. its hard to blame that on the manifold but the stall definately wouldnt give you more mph. you also have more cubes so i would bet you have more to gain with the mod.
Old Mar 17, 2009 | 10:40 AM
  #28
nighthawk08's Avatar
the ls2 intake will not make more power than the LS6. this has been tested.
Old Mar 17, 2009 | 10:44 AM
  #29
thanks. aparently nobody beleaved me when i said it hahaha
Old Mar 17, 2009 | 10:47 AM
  #30
BlackGMC's Avatar
Resident Retard
If your going to be running that much nitrous are you not scared about blowing that fast intake into peices? Isn't that what Tarnitup did?
