X-pipe VS no X-pipe
Old Nov 29, 2005 | 01:30 PM
1BadAction's Avatar
Registered abuser
Default X-pipe VS no X-pipe
on a true dual setup, how much power difference is there? would i make more with an X or without?
Old Nov 29, 2005 | 01:38 PM
You'll do alot better w/ an X-Pipe....you won't loose as much low end torque.
Go w/ an X-Pipe instead of not having one or using an H-Pipe
Old Nov 29, 2005 | 01:59 PM
F8L Z71's Avatar
Are you asking is it better than an H-pipe or do you mean making true duals with no crossover pipe whatsoever?
My choice is for an X over the H but that is mainly for sound reasons. Generally speaking the X-pipe is quieter than ther H-pipe. HP wise there is not a huge difference in all the testing I have seen.
You need to run 1 or the other though.
Old Nov 29, 2005 | 02:27 PM
1BadAction's Avatar
Registered abuser
why cant i run no crossover? The GTO doesnt have a crossover (theres a pipe there but its closed from the factory) and it seems to run fine.
If im only going to gain 3hp from an x pipe over none, then im not going to run one.
Old Nov 29, 2005 | 02:34 PM
StrokerAce03's Avatar
You don't lose as much lowend with the x-pipe as with just true duals from what i've heard. I used to run true duals with straight pipes and lowend went to ****. The x increases the scavenging (sp?) effect and equals out the pulses between the left and right banks.
Old Nov 29, 2005 | 02:36 PM
Tractionless's Avatar
HERE is a link I found to some info on the X and H pipe.
Some info posted by Blaster on post #9 in the link.
"H pipe will balence pressure in both pipes BUT X will also scavenge the gas to help evacuate the engine cylinders. Think about the way an engine fires and imagine each exhaust stroke as a pulse, one after each other. As a pulse travels down the pipe and crosses over in the X it should, in theory, create a vaccuum and help pull the next exhaust pulse on the other side. I also believe cam overlap together with a high flowing (velocity) exhaust also helps eliminate intake reversion and helps bring more air into the cylinder.
X pipe will sound a bit quieter than an H pipe too."
I have the Magnaflow X-Pipe part #10790 in my truck with dual 2.25" exhaust. Magnaflow x-pipes are really nice. I bought the not stainless one for around $65 from a local authorized Magnaflow dealer.
I've also heard that you get less poping sound in the exhaust when the truck is decelerating. (sp?)
Hope this helps.
Old Nov 29, 2005 | 02:40 PM
1BadAction's Avatar
Registered abuser
thanks, I searched an hour and didnt see that thread.
Old Nov 29, 2005 | 07:16 PM
dry_kill's Avatar
I'd say go with an x pipe, a buddy at work has true duals that go all the way back, no x pipe or nothin and it sounds raspy *** hell and pops really bad, sounds like he has a honda engine in there horrible, so I say go with the x pipe
Old Nov 29, 2005 | 10:18 PM
BLASTER's Avatar
Tractionless, thanks for the reference :-)
For 5 years I had straight duals without a crossover and much like StrokeAce already mention above, lowend torque will be down. Without a crossover of some sort, each engine bank will "see/feel" different resistance from the pipes, especially since the exhaust system doesn't go straight back. Don't forget, the drivers side gets alot more pipe than the passenger side.
Old Nov 30, 2005 | 12:05 AM
Black_Silverado_5.3
22
Jan 17, 2005 10:36 PM
BLACKND
17
Dec 20, 2004 08:13 AM
davidmtz
Jan 16, 2004 07:22 PM
ranwalk
Apr 8, 2003 11:05 AM
