Wtf... Lm7, Lq4???
Old 08-13-2005, 05:00 PM
DakotaKiller5.3's Avatar
Default Wtf... Lm7, Lq4???
ok... now i am really corn-fused. i had always thought my 2000 5.3 was an lq4. read an article in PHR for a rocker and pushrod install and they called it a lm7 (however, it was done on a 04) so... what the H$%@ do i have? what is the difference in the two. LQ4 should have 101mm bores and the LM7 has like 90 something right? correct me please.
Old 08-13-2005, 05:06 PM
It is indeed a LM7. The LQ4 is the 6.0 they put in 3/4 ton trucks(lower compression than the LQ9). LQ9 is the 6.0 put is the SS, some Escalades and the VHO(10:1 compression).
Old 08-13-2005, 05:08 PM
ok. that is a start... what is baseline hp and tq #s for this thing? for an EC even before mods it was pretty quick for a whale
Old 08-13-2005, 05:13 PM
white1's Avatar
2000 5.3 is rated at 285/325 Sure you weren't thinking about the LM4? It wasn't available till 03. It was rated at 290/330
Old 08-13-2005, 05:20 PM
not quite positive on that. it was a shocker... the whole time i was thinking lq4, it wasnt. ahhhh. what else is different? is it atleast a 4l60e? damn, maybe i dont know as much as i thought.
Old 08-13-2005, 05:37 PM
white1's Avatar
Yes it is the 4L60E. Unfortunatly.
Old 08-13-2005, 05:47 PM
Default unfortunatly?
why is this? i thought this was the trans to have, seems lots talk about the G80 as a piece. what is the diff?
Old 08-13-2005, 10:16 PM
G80 is the locker in the rear end. Nothing to do with the tranny. The 4l80e tranny is the tranny to have. It comes in 3/4 ton trucks with the LQ4 motor. 4l60e trannies break under just about any significant horsepower.
Old 08-14-2005, 12:32 AM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Or you can dump 3grand in to the 60E and pray that it holds up like I did the 80E swap is just to much in a 4wd IMO and I think I will be fine with an extremely built 60E. Damn 5 poinion planets are 450 bucks.
Old 08-14-2005, 12:57 AM
white1's Avatar
When/if mine blows, I wanna 65.
Quick Reply: Wtf... Lm7, Lq4???
