Why is my 408 a dog down low?
Old Jan 12, 2007 | 05:32 PM
  #61
Originally Posted by thunder550
Care to share your cam specs?
the specs are in the clasified section where he has his truck for sale.
Old Jan 12, 2007 | 05:56 PM
  #62
03sierraslt's Avatar
Originally Posted by Snake Eater
GM says the coil packs are good for 200,000 miles at 8ms. Increasing them to @6.5ms may shorten there expected lift to @300K miles, and thats not all that bad. There was a huge write up about dwell increase on the tech. It made a noticable difference when i did it.
A NA LS motor usualy hits peak hp with 29-31* timing at WOT.
I was going to mess with dwell as well but the HPT guru's claimed that it wont do anything. Someone did dyno runs to see if there was any gain and there wasnt. I dont know.
Old Jan 12, 2007 | 06:29 PM
  #63
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
That cam is NOT too big. If I could spin all four with my old stock motor and a bunch of other BS in the bed for 10-15 feet in 4hi then you should be able to spin them for a while in 2hi. Main differences being my stall was about a 3800, 237/242 112 cam and going through a 60e but we are also talking about more weight in my case and 4wd vs. 2wd. Also look at what the Wooh Hauler is doing with his cam(233/239) with 10:1CR, in a 2wd with a 60e but he spins through second so obviously there is something else up besides the cam IMO.
Old Jan 12, 2007 | 07:12 PM
  #64
thunderwagen's Avatar
Thats a damn good deal. I paid $1,100 for 4.10's and detriot locker in my 2 silvy's. Both 2wd and both done at 4wheelparts.
That was for gears only and reusing the diffs in the truck.
Old Jan 12, 2007 | 07:35 PM
  #65
onebadrubi's Avatar
I don tthink you can compare the wood hauler's low end torque as of a few days and prior to that guys.
Wood hauler. 4.10 28"s radial tire. 4k converter 4l60e. Close enough to same cam specs. More "torque" manifold using the truck manifold.
Thunder 3.73's, 2800 converter, 33" tire, 4x4 EXT cab, lower compression. 4l80e.
Old Jan 12, 2007 | 07:38 PM
  #66
1slow01Z71's Avatar
Jus trying to show he should get more then a squeek out his tires, I had 32s on my truck and 500#s in the bed and a larger cam, care to explain the results on that one with me being in 4hi and him in 2hi?
Old Jan 12, 2007 | 10:48 PM
  #67
parish8's Avatar
single digit dreamer
i put my cam specs in the post above. 234/232 ~590 lift 114+1. and i lost power everywhere below 4000rpm. a 3800rpm stall would help a ton but i would consider that a prety track friendly stall and not all that great for a truck if your going to use it as a truck, you wouldn't want to tow much with a stall like that.
Old Jan 12, 2007 | 10:57 PM
  #68
parish8's Avatar
this wasn't easy to find. these 2 charts are for a 6.0 with the 234/232 590lift 114+1. the lower peek numbers are stock cam. the higher numbers are with the above listed cam. you can see where it was 4600rpm before the bigger cam took over the stock cam but from there it killed it. incredable loss of low end if you ask me. sure a 4000rpm stall or even higher and the truck would have been way faster with the big cam but with a moderate stall the driveability went down considerably.
Old Jan 12, 2007 | 11:04 PM
  #69
Jim, we dont see no charts. Put the beer down, it wasnt that hard of a friday. LOL
Old Jan 13, 2007 | 08:06 AM
  #70
litreddevil's Avatar
Banned
i see charts
