Why is my 408 a dog down low?
#71
Originally Posted by Snake Eater
Jim, we dont see no charts. Put the beer down, it wasnt that hard of a friday. LOL
#75
Originally Posted by Quik
i ran the 232/234 595/598 112 in my 11.1 6.0 ran fairly well but i did use a 3800 stall. up top is where it showed even with my fuel issue.
#76
Originally Posted by parish8
there is no doubt a 3800rpm stall would fix him up. it all depends what the truck is going to be used for. a 3800rpm stall is prety high for a truck if it is going to be used as a truck. it is prety high for a turbo vehicle too. when the massive tq(boost) hits on that 408 a 3800rpm stall might just blow thru to 6000+rpm and stay there.
#77
High on diesel fumes
That is a HUGE difference
Thanks for the charts Jim. I do plan to use my truck as a truck, it's a DD and a tow vehicle. Stalling up more isn't at option for me right now.
Like I said before, if I have a setup that will perform well with a turbo, I can deal with it being slow off the line for now. I don't see any reason to spend money on making this a good N/A setup when I plan to go turbo in less than a year. I appreciate everyone's help so far, this thread has been very informational.
Unfortunately the track was closed last night because it was raining, so I went out drinking instead
didn't get a chance to get any logs. I can't feel a SOTP difference from increasing spark dwell, but I haven't messed with the timing either.
#79
what is the full specs of that cam? from a quick punch in the dcr calculator i'm getting more like 7.5 which is where your bottom end is. if you had a 8.5 dcr you would have monster low end.
#80
I also ran your engine size and cam spec # thru the LS1Tech DCR calculator and I get less than 7.28. I didn't have the .006 numbers so I pluged in 284 & 288. That big of a cam is going to have more than 1 point difference between SCR and DCR. Even a small Comp XE 212-218 .558-.563 on 114+4 comes in at 7.78 on your combo. This could play a big part in the soft bottom end response, especially stalling at 2400. Hope this helps.
Ron
Ron
