Why is my 408 a dog down low?
Old Jan 12, 2007 | 03:06 PM
  #41
Originally Posted by silverbrick
but if you increase it too much the coil packs will stay dwelling through multiple spark sequences right? say your dwell is 8ms but there are only 7.8ms between sparks? That wouldn't be good... I know there has to be HIGH rpm for this to happen but still. Also with longer dwell your coil pack life is lessened.
GM says the coil packs are good for 200,000 miles at 8ms. Increasing them to @6.5ms may shorten there expected lift to @300K miles, and thats not all that bad. There was a huge write up about dwell increase on the tech. It made a noticable difference when i did it.
A NA LS motor usualy hits peak hp with 29-31* timing at WOT.
Old Jan 12, 2007 | 03:10 PM
  #42
Thanks for the info, I was just thinking conceptually, not with real life numbers.
Old Jan 12, 2007 | 03:13 PM
  #43
thunder550's Avatar
High on diesel fumes
Originally Posted by tdrumm
What are the VEs on your cam? I bet that with the 9.5:1 SCR, and a cam of that size, your DCR is in the mid 7 range. I think that could make it sluggish down low.
My DCR is about 8.5:1. I ran it through a DCR calculator.
Good info to know. I'm running about 26* at WOT right now, looks like I have plenty of room to play with.
Originally Posted by mds2004
I think the culprit is your motor. It is useless and you may as well pull it out and hand it over to me. I will make it spin for you
Ok My house needs new wall paper too, so you might as well come and take that too
Old Jan 12, 2007 | 03:17 PM
  #44
Zick's Avatar
What's your spark table look like?
Old Jan 12, 2007 | 03:19 PM
  #45
thunder550's Avatar
Spark
Old Jan 12, 2007 | 03:20 PM
  #46
Zick's Avatar
Do you have a log of it when your feeling this dogness? Are you possible not getting the spark that your commanding?
Old Jan 12, 2007 | 03:23 PM
  #47
thunder550's Avatar
The highlighted cell on the table is where I'm at when brake stalling, .64 g/cyl and 2400 RPM. Commanded, based on the spark table, is 27*, actual from the scanner is 24*. I haven't figured out where the other 3* are being lost yet, but actual timing is definitely 24*.
I don't have any logs of a hard launch yet, I just remember the .64/2400
Old Jan 12, 2007 | 03:34 PM
  #48
Zick's Avatar
Make sure burst KR isn't pulling the timing. I had quite a bit of timing getting pulled from my Burst KR table.
Old Jan 12, 2007 | 03:35 PM
  #49
thunder550's Avatar
I de-sensitized BKR - I'm wondering if I should just set it to zero. Where's yours?
My delta airmass table is .600 all the way down.
Old Jan 12, 2007 | 03:39 PM
  #50
Zick's Avatar
I have mine set at .040 and it kept mine from getting burst KR.
Edit: I'm also using HPT so it may be a little different I don't know.
