wheres the RPM connection for 02 Turbo 6.0
Old Jul 4, 2005 | 10:19 AM
NXRICKY's Avatar
Former Vendor
Question wheres the RPM connection for 02 Turbo 6.0
After connect the dual channel wide band I realized I did not which wire is the tach signal,
Can anyone tell me what wire they are connecting to?? This is the last point of the install and I am stuck.
Ricky
Old Jul 4, 2005 | 10:31 AM
parish8's Avatar
single digit dreamer
on both of my trucks i taped onto the white wire just as it goes into the cluster. you have to pull the cluster to see it.
Old Jul 4, 2005 | 12:09 PM
kbracing96's Avatar
I did the same thing on my 01 for the wideband rpm feed. White wire behind the cluster.
Old Jul 4, 2005 | 01:45 PM
NXRICKY's Avatar
Former Vendor
ok what cluster? Can I get a little more info. Still new to some these electronic gizmos.
Ricky
Old Jul 4, 2005 | 02:04 PM
TURBHOE's Avatar
i'm guessing probably your guage cluster: speedometer, tac, water temp, batt voltage,fuel gauge,....... that cluster.
Old Jul 4, 2005 | 09:22 PM
kbracing96's Avatar
Ya, its the guage cluster, pop the trim off and take out the 4 screw holding the cluster in and there is a pigtail that plugs into it. It's the white wire in it. Its really easy to find.
Old Jul 5, 2005 | 09:17 AM
NXRICKY's Avatar
Former Vendor
Thanks for all the help, have not found a throu hole yet , from the engine compartment to the inside. Any suggestions, or just get a drill and get it.
Ricky
Old Jul 5, 2005 | 12:41 PM
TURBHOE's Avatar
thats what i did drilled a nice little hole in the fire wall on driver side kinda to right and up of the driver manifold there was a flat spot about the size of a quarter worked great.
Old Jul 5, 2005 | 01:09 PM
NXRICKY's Avatar
Former Vendor
thanks.
Ricky
Old Jul 5, 2005 | 01:43 PM
BlownChevy's Avatar
blownerator
25 Year Member
Pin # 10 Red PCM Connector. Should be a white wire, that is where I would grab it. I am pretty sure the 02 has a Red and Blue connector.
Oobray
Jun 13, 2022 03:38 AM
greedygenius
Sep 3, 2015 06:51 AM
05GMC4.8
Aug 7, 2015 09:55 PM
steves86ta
Jul 28, 2015 10:21 AM
